Old 03-07-2006, 04:13 PM
rgfritz rgfritz is offline
Question Front End Rebuild
I'm getting ready to rebuild the front end in my '98 Astro. I plan to do ball joints, tie rod ends, idler arms and any bushings that may need replacing. Does anyone have a recommendation of what brand parts I should look for? I want this stuff to last....don't want to do it again anytime soon. Thanks in advance.
Ron
Old 03-07-2006, 07:58 PM
CD Smalley CD Smalley is offline
Re: Front End Rebuild
MOOG! And find the Problem Solver versions if you can, these will have a T in the part number.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 03-09-2006, 09:22 PM
old_master's Avatar
Advisor/Moderator
I second that! MOOG problem solver and nothing else, it's simply the best! I've done front end work for over 30 years, MOOG! Make sure your center link is level when you tighten the idler arms down, and the wheels are straight ahead when you tighten everything else, (ball joints, tie rod ends etc) and use a torque wrench.
Old 03-17-2006, 09:06 PM
shroom59 shroom59 is offline
Send a message via Yahoo to shroom59
thats right on the center link, otherwise you'll throw off the wheel 90 degrees, like i did,,duhhhhhh, make sure the sterring wheel is in lock position, iooooops i forgot to do that one.
