Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-07-2006, 03:29 PM
KE.street.styler KE.street.styler is offline
Cool Good Idea/Bad Idea?
Hey everyone. Here's a situation for ya:
I can buy a 96 Eagle Talon non-Turbo with 150,000 miles for $1,000. Problem is, it burns oils which tells me that it needs a rebuild. Normally, I'd be all over it, but it has an automatic tranny. I hate automatics....
So here's the question:
Is it going to break my budget to buy it, rebuild it, and do a tranny swap? Would it make more sense just swap the engine-tranny-drivetrain with an EVO? This is a budget car, so lets not get outrageous, ok! What's the most sensible choice?
As is, I'm thinking about passing it by, but the car does run...so it is tempting. I just don't like the fact that it's an automatic transmission.
"There's a thin line between not listening, and not caring. I like to think I walk that line every day."
-Church
-RvsB
Old 03-07-2006, 03:33 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Good Idea/Bad Idea?
If you are going to swap the tranny. It's definately not worth the money. Swaps can be expensive and there is no way of knowing why it burns oil. And rebuilds aren't so cheap if you are looking for a budget car. I would hold out on something else. Perhaps with a turbo?
1991 GSX 2.3 Stroker
Old 03-07-2006, 06:01 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
the transmission swap costs more than the car is worth. add that to an engine rebuild and you'd have $6000 into a $3000 car.
swapping the evo drivetrain into a Talon ESi would cost more than buying an Evo or a solid 6 months of work.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 03-07-2006, 09:16 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
It would be a bit less then that unless you buy all new parts . I bet you could do it for $1500 (if you do it yourself). I doubt you can do an evo engine/trans/drivetrane swap for cheap.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-08-2006, 12:41 AM
Thanks everyone. I'm gonna follow my initial thought and pass on it then. I should be able to one in better condition, with a manual. It'll cost more to boot, but at least I know it won't die on the drive home.
-Church
-RvsB
Old 03-08-2006, 08:06 AM
ez1286's Avatar
You should buy a turbo dsm!!!
Old 03-08-2006, 10:05 AM
I'd love to buy a turbo DSM. But I'm looking for an all-motor budget project car. I'm thinking; buy a car for no more than $3,000, put no more than $2,000 under the hood and $3,000 into the exterior. Obviously I want to go with a popular car like an eclipse, civic, or integra so I can get more parts for less money. At the same time, I'm going to use my budget-project as a dialy driver and moniter it's performance closely. I'm trying to see the long-term effects of tuning a car for racing and then driving that car to and from work, the store, where-ever. If I keep my records well enough, you might see an article in Import Tuner about it in a couple of years.
-Church
-RvsB
Old 03-08-2006, 11:10 AM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
parts for eclipse's are expensive!
Old 03-08-2006, 12:26 PM
ez1286's Avatar
Tou can get a 1g and possibly a 2g for 3k, 2k in mods wll go much farther in a turbo car than in an na car.
Old 03-08-2006, 03:08 PM
Performance parts for any Japanese import is expensive compared to Domestic cars. On the flip side, they're cheaper than parts for German imports.
Anyway, the car will eventually go force induced. But i don't do things half-way. In order to properly turbo a car, you have to rebuild it; resleeve it, and throw in forged internals. Else wise you'll eventually blow your motor. Performance rebuilds aren't cheap at all, which is why I'm going naturally aspirated for this project. Spending $2,000 on a bolt-on turbo will give me more bang for my buck, but it's the literal 'BANG' that I'm trying to avoid, savvy?
-Church
-RvsB
Old 03-08-2006, 03:22 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
He wasnt talking about buying a giant turbo on a stock block, with even just intake and exhaust youll get bigger gains then u would on a na car, and the cost to turbo a gs/rs will put you around the stock hp of a gst/gsx.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 03-08-2006, 06:02 PM
So what are you thinking? A Garrett T3/T4 hybrid at 6psi with a front mount intercooler and turbo-back exhaust? Isn't that still gonna cost around 3 or 4 grand?
-Church
-RvsB
Old 03-08-2006, 07:27 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
I think you mis understood him. He means that putting exhaust and intake on a N/A car compared to putting exhaust and intake on a turboed car you will see more gain in power on the turboed car. Also, no not 3/4 grand. I just purchased a HUGE fmic complete kit for under 300 bucks. A T3 im guessing would be a little under 1000 bucks something like 900. SO, putting alot of money into a rs/gs eclipse then turboing it would put you at lets say 250hp or so. The stock hp on the gsx/gst is 210. What everyone is saying is that if you want a good amount of power from your mods the gsx/gst are a better choice.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 03-08-2006, 07:29 PM
NateS's Avatar
Oh, and if I was looking for a non turbo car, I do not think I would go with that car. 150K and its an auto. Personally, I would pass it up. Non turbo eclipses/talons are not hard to come by.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 03-08-2006, 07:40 PM
Gotcha, thanks. I did misunderstand him. It's been a long couple of weeks, what can I say? The GS-T and GSX is getting pretty rare though these days, isn't it? Even if I found one for $3,000, what are the odds of it being in relatively good condition? More importantly, what are the odds that the tranny will still be in good shape? Don't get me wrong here, I had an 01 Eclipse and I loved the life out of it. But I also realize that Mitsu doesn't make very dependible transmissions.
-Church
-RvsB
