Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-07-2006, 04:28 PM
pov02 pov02 is offline
Smoke from oil cap???
Hi guys, i've started my gsx yesterday for the first time from a major engine rebuild. But I noticed that a mass of smoke is coming from my oil catch can (connected from both nipples from valve cover). Then my cousin came over (original owner) and said that that was not normal. So we opened the oil cap and smoke came out constantly including some oil being squirted out. He said that maybe one of my exhaust valve is not seated right, but we don't know for sure yet. If any of you dsmers encountered this problem or think what can be the problem, please help me out a little. Any reply would be appreciated. thanks
(also, would the pcv connection have anything to do with this?)
Old 03-07-2006, 04:30 PM
Re: Smoke from oil cap???
Almost forgot, this is what i have in the rebuild
Engine:
HKS 264 272 camshafts
HKS camgears
JDM lifters
Crower Titanium Retainers and Springs
Ferrea Valves (1 mm over)
Port and Polished Head
Port and Polished stock intake manifold
Cometic Head Gasket
ARP Head Studs
JE Pistons (.02 over)
Eagle Rods w/ ARP rod bolts
Kings Main and Rod Bearings
Balanced Crank
Balance shaft removed
Following parts are new :
Block Freeze Plugs
Oil pump
Water pump
All timing and crank pulleys and belts
All gaskets and seals
Bolt-ons:
Slowboy FMIC w/ HKS BOV
GM MAFT
Polyuerthane Motor Mounts
Fluidyne Radiator
SPAL puller fan
RRE oil catch-can
FP 4" intake w/ K&N filter
60-1 T3/T4
Tial 38mm wastegate
Victory O2 housing
Apexi 3" downpipe
custum straight pipe through Apexi N1
ACT Streetlite Flywheel
ACT Extreme pressure plate 2600
ACT Street disc (hope but might burn)
TRE fully rebuilt with all of extra modification
with SPOOL instead of spider gears (busted and unreusable basket)
Fuel:
Walbro 255 lph
-6AN fuel line from tank to rail
Aeromotive rail
Aeromotive regulator
750cc RC injectors
Electrics:
PLX M-300 wideband
Dsmlink
MG ECU (don't really matter, but its new)
BR coil on plug
MSD Dis-2
NGK plugs
i think thats all i got excluding Defi gauges and Blitz turbo timer.
Well anyways, alittle help on the driveshaft might help.
Thanks alot guys!!
Old 03-07-2006, 04:32 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
This would belong in the Problem Diagnosis sub-forum.
Are you sure you put everything back together right? I'll have to think about this.
1991 GSX 2.3 Stroker
Old 03-07-2006, 05:17 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
The cap might not be sealing correctly
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 03-07-2006, 06:33 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Sounds like you have a good setup going. Only thing I can think of is excessive blow-by.
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-07-2006, 08:05 PM
SLoe's Avatar
SLoe SLoe is offline
yep yep Did you put it together yourself?
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 03-07-2006, 08:55 PM
Yeah, my brother and i did put this together, except the porting the head and manifold, installing the valves and retainers with springs, and overboring. but other than that, i guess we did do it all. It took us four years including work and school, but yeah we finally finished (due to revenge on twelve second supra and el camino). This may be a really idiotic question from me, but what exactly is blow by if you don't mind me asking. My brain is fried like i've been doin drugs or something, i just can't really think rite now.
Thank you guys very much for the reply though, really appreciate it!!!
Pao
Old 03-07-2006, 08:57 PM
blk_srt's Avatar
blowby is combustion gases passing by the rings into the crank case
Mods:
Old 03-07-2006, 09:47 PM
SLoe's Avatar
Beat me to it, damn.
Did you check the piston to wall clearance, and the taper on the cylinders? End gap on the rings? Did you install the rings right side up, and in the proper grooves.... etc.etc. I am not trying to insult you here, just trying to get an idea why you would have poor ring seal in a freshly machined block.
Old 03-07-2006, 10:32 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Try doing a compression test to see if you can narrow it down to one cylinder. Unfortunetely it sounds like you need to tear that bitch apart again.
EDIT: Did you put new valve stem seals in?
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-07-2006, 10:33 PM
blk_srt's Avatar
Mods:
Old 03-08-2006, 05:27 PM
Aww SNAPS!!! I forgot to buy new valve stem for this mother load . Do you guys think i need it because its something that should have been done to begin with. Also, don't worry i take no replies from you guys as an insult. Any reply is appreciated. The only thing that i can think of about the rings is that the JEs is a birthday gift from brothers to brother from ebay. It then made me think if the rings are legit, hell, if the whole piston is legit. All the other internals are straight from websites (dsmparts, turbogarage, forced performace, etc...). The next thing is, if the gaps on the rings are alined, My brother did the piston install when i was at work and he made sure the gaps are separated, but due to the ring clamps (the ones from autozone that rotates as you tighten the clamp) might have rotated them to line each other, if not close to each other. Yeah, a compression check is not a bad idea, I'll do that tonight after i'm done swapping springs, shocks and pads for my neighbor.
Yeah you guys might be right, we might have to tear the son of a gun apart again (i like using this symbol cause its exactly what i'm doing).
Thanks again for the response guy. Gladly appreciate it!
Old 03-08-2006, 05:55 PM
blk_srt's Avatar
the valve stem seals probably could do it to. It would let exhaust gases into the valve cover area and also oil could get down into the combustion chamber
Mods:
Old 03-14-2006, 08:50 PM
Yeah guys, finally did a compression check. The number four runner is at 140 while the other three is at 170. Guess I'll have to tear the SOB apart again, I think I'm gonna take the head to get it pressure checked just incase one of the valves is not sitting right or maybe the valve guides are old. Then, we're gonna have to take out the piston too to see if the rings are aligned if not fried. While I'm at it, I just ordered the external oil cooler kit from machv then I also have an Earl oil cooler core coming in too so might as well slap those on too. Damn, it sucks to find out that I got this problem too. Because as i posted on the other forum, my gears will not go in!!! Its been pissin me off for the longest time. If you guys wanna hear about this problem too then reply back on the other page. I posted it for quite some time now. If you guys can't find it, i'll be more than happy to post another page telling the most recent approach we did.
