Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 03-07-2006, 02:06 PM
orionshines orionshines is offline
How do I reset 4 wheel drive sensor... amber message
Had a oil change business service 4 wheel drive, but they didn't know proceedure to reset sensor so Ive got the amber light some times... "Service 4 wheel"
Old 03-07-2006, 02:42 PM
Re: How do I reset 4 wheel drive sensor... amber message
2000 xl slt
Old 03-26-2006, 05:35 PM
bndfishing bndfishing is offline
You don't reset the light, it is not a service light like a change oil light. You have the light because a code has been set. You need to have it scanned find out what code is set, diagnosis the problem and then the light will go away.
Old 03-27-2006, 08:28 PM
I had it scaned today for $60 and got a error code of b2725 one of the swiches is out...
Can you tell me which one and where to look for it if it is accessable!
Thanks!!!
Old 03-27-2006, 08:37 PM
b2527 code is where the failed switch is... Can you tell me about this switch?
Where it is and if it is easy to change.
Thanks
Old 03-27-2006, 08:41 PM
I need year, make , model then I can help you.
Old 03-27-2006, 08:52 PM
also you have it listed as 2725 and 2527 they are way not the even close I am going to assume it is 2725 (range mode switch voltage level outside possible range.) So what is it telling you is that the selector switch is what has thrown the code. It is a 3 page trouble tree if you have a fax I can fax it to you Tuesday night when I get home.
Old 03-30-2006, 10:19 PM
VTFan VTFan is offline
I have a 2000 Yukon with the same message. Depending on mileage, the light may or may not be valid. In my case I had a buddy look at vehicle and current TSB's (GM or CMC technical service bulletins) and , sure enough, there is a TSB on this issue. Four wheel not the issue, the switch on the dash IS the issue. Went to dealership, replaced switch, and solved the message center light.
Old 05-26-2006, 09:57 AM
masiri masiri is offline
Yukon 2006 xl
I had the frist oil change then i got "service 4WD". Also the switches didnot respond . What shoud i do
