I Brought My Explorer In To The Dealer To Diagnois A Vibration Between 2000-2500 Rpm. They Say It Is The Timing Chain Tensioner. According To The Shop Manual There Are Special Tools Required As It Does Not Appear That There Are Timing Marks.
1. Is It Possible To Change The Tensioner Without Replacing The Chains And Upsetting The Timing? 2. The Vehicle Has 130,000 Miles And I Want To Keep It Another Couple Of Years 30k/year, So Should Ialso Change The Chains To Prevent A Breakdown? 3. Are There Other Possible Causes For The Vibration I Should Check. Thanks, Ken |
Re: 2000 Ford Explorer 4.0 Sohc Timing Chain Tensioner
There is a parts kit available, they change the tensioners only, not the chain. The timing tool can be had for under 20 bucks on the net. That should get you started! |
michael n.
"when in doubt gas it" |
Dealer should not charge you to check the history of the vehicle and tell you whether that fix was done. They will check and be sure all offical recalls have been done. |
I wonder if maybe the harmonic balancer at the crank may have slipped in the rubber. I am not sure about the tensioner. Do you hear a rattle when it idles???/ Deerecrouse
) and check out the previous recalls and the O rings while i'm there.. thanks so muchQuote:
mike
