Old 03-07-2006, 09:32 AM
ljshein ljshein is offline
'91 Grand Caravan SE 3.3 Issues
All,
I'm new to the world of caravans but not autos in general. I friend gave me this vehicle for my sister who is down on her luck and needs a bit of help. I'm going to try and make it safe and reliable but need a little help.
There are 3 issues that need to be addressed:
1. There is a bad relay or connector for the gauges on the dash. I'll hit a bump and the gauges will all flatline. Hit another and they all come on, the auto door lock engauges and the ABS sensor resets like when you first turn the key. Checked the fuses so I'm guessing a relay. I have a haynes book on order but any advice in advance will be appreciated.
2. Press on the brake pedal any more than a soft stop and the ABS and emergency brake light come on. The brake pedal is firm and the van stops well. Plenty of fluid in the tank. Seems like a sensor more than anything else. Any suggestisons are appreciated.
3. There is a bearing noise from the front of the motor, about the place the altenator sits but I haven't pulled the belt off to try and isolate it yet. Any common issues in that area?
Thaks in advance for the assistance!
Jeff
Old 03-07-2006, 05:03 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: '91 Grand Caravan SE 3.3 Issues
First, scan the computer for error codes.
Loose connection or bad solder joint on the printed circuit board for the instrument cluster?
You might want to start with a brake system flush and bleed. Could also be a bad ABS Sensor.
Belt tensioner or idler pulley, bearing in alternator.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
