Old 07-02-2002, 01:37 PM
Phat_Si's Avatar
Phat_Si Phat_Si is offline
Send a message via AIM to Phat_Si
z6 dizzy problems???
ok, i want to do the z6 head swap into my rex. Does anyone have pics of what the dizzy looks like when the swap is complete. I know you have to leave like a gap or something but i don't completely understand it. could someone either describe this to me in extreme detail or give me some pics of some of the setups you have seen??? please help me out!
-----'89 Crx Si-----
I/E
NGK plug wires
Custom backseat
Rims
clear corners
Awia head unit w/Pioneer speakers
Blowin' Smoke!
--Soon To Be--
slammed
new D16a6 block
sohc vtec d16z6 head, P&P'ed
gude stage 2 cam
gude cam gear
some fuel goodies etc...
Old 07-02-2002, 01:59 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
this is a crappy pic...but...
http://crx.honda-perf.org/articles/z6swap/z6swap.html
SOLD!
Old 07-02-2002, 02:10 PM
marked001's Avatar
Moderadur
p.s. - try to post this stuff in the proper forum
SOLD!
Old 07-02-2002, 02:26 PM
Phat_Si's Avatar
Anybody else have any pics or can describe it??? oh, and sorry about the posts being in the wrong place!!!
I/E
NGK plug wires
Custom backseat
Rims
clear corners
Blowin' Smoke!
--Soon To Be--
slammed
new D16a6 block
gude stage 2 cam
gude cam gear
Old 07-02-2002, 03:42 PM
marked001's Avatar
Moderadur
this was pulled off of someone's page...
DISTRIBUTOR
92-95 WON'T work with 89-91 ECU. Use 89-91 si. You'll have to modify it somewhat if you're using D16Z6 block. No fancy machining needed. Just do it right and use big washers on the bolts and then get it timed to the red mark of the pulley. The distributor has 3 mounting holes: one closer to the fire wall (don't touch this one), one sort of on top and one closer to the rad. These two will have to be cut/modified. Not that much of a deal though, eh?! But, if you're swapping in the D16Y8 from a 96 on civic, your 4G distributor will bolt with 3 bolts onto the Y8 block!
http://www.angelfire.com/ca/DrOhm/im...istributor.JPG
The distributor can be installed using 2 mounts only seen on the above picture. The one in the back requires an adapter. Aaron made one for me. It's in an L-shape. 2 bolts hold the adaptor.
N.B. It would be a good idea to install the distributor without cutting it first, get the ignition timing done and see exactly where is has to be modified. That way you won't cut too much. Just hold the distributor with VISE grip. The picture above will give you a rough idea where the stock timing position is at.
edit: cut and paste the link for the pic and it should work...
SOLD!
