Old 03-07-2006, 02:04 AM
phess phess is offline
Arrow battery or alternator???
my battery voltage goes up and down.mornings is high about 14.5 volts or alittle less.during the day it is about 12 to 13 14 then sometimes it goes from 12 to 14 fast it keeps going then 13 to 12,,12 to 14 ,,14 to 13 and so on.my belt is ok ,not loose or to tight.i replaced the altertator.its a brand new one.does anyone know.can it be the ELD.electronic load detector??????????
Old 03-07-2006, 03:21 PM
somick's Avatar
somick somick is offline
Re: battery or alternator???
If you got a new alternator then it sounds like a bad votage regulator (unless your's is built in). What kind of car is it?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 03-07-2006, 08:23 PM
ita a 2000 honda accord ex v6.is it hard to change it.will it affect my car performance??
Old 03-07-2006, 09:03 PM
somick's Avatar
Unfortunatelly I do not know your particular model. But it definetelly will affect your car's devices and/or equipement. Most auotmotive stores perform free testing of alternators and batteries.
Consult Haynes manual. This is my best friend!
Let us know what you find.
Old 03-09-2006, 02:18 AM
o kool thankz
Old 03-09-2006, 03:58 PM
mpumas mpumas is offline
Why do you feel you have a problem? Is your battery going dead? Voltage out of the alternator will vary based on engine speed and also current draw as determined by the ELD, so I would expect some changes. The only thing that can be said for sure is that the alternator should put out about 14.5 volts when the engine is running above 2000 RPM and when the battery needs charging.
