Old 03-06-2006, 10:38 PM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
need help with SATA drive
ok, i built a computer the other day, and am trying to use a SATA drive. Specifically a hitatchi desktar 250gb drive. I am using the SATA ports that are on my mother board (abit NF7-S2G). when I acces the CMOS at power-up and go through options, it recognizes my hard drive as channel 3 master. sorry i can't be more specific right now, but any help will be aprecaited
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 03-07-2006, 12:57 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Re: need help with SATA drive
What jumper setting is the hard drive on? Try it on Master and Cable Select, and post your results.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 03-07-2006, 02:08 AM
mike1224's Avatar
its jumperless.
2002 Chevy S-10 ZR2
Old 03-07-2006, 04:41 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Hmmm....have you tried updating your BIOS?
Old 03-07-2006, 10:18 AM
mike1224's Avatar
thats next. i'm taking the HD out of this computer and putting it into the newer one.
2002 Chevy S-10 ZR2
Old 03-07-2006, 05:17 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
I don't get the Channel 3 master thing in CMOS. Shouldn't it be primary master? Anyway, the BIOS update should solve any size problems.
Old 03-12-2006, 02:58 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Channel 3 master is the hard drive. SATA drives are jumperless because there's no way to run two on the same connection as with IDE drives. It says channel 3 because you have 2 ide channels that take precedent over the sata drive. The computer does not need a bios flash because of this as it will still work fine.
Old 03-12-2006, 03:06 PM
mike1224's Avatar
unplug the CD &DVD roms, and I should be fine??
2002 Chevy S-10 ZR2
Old 03-13-2006, 01:43 AM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
did ya get this fixed yet mike?Im following you around AF
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 03-13-2006, 01:47 AM
mike1224's Avatar
nope... i think i'll throw in my IDE drives in for now.
2002 Chevy S-10 ZR2
Old 03-18-2006, 08:39 PM
mike1224's Avatar
ok guys I apprecaite the help now heres another thing. I've got WinXP on a IDE drive, works good, with RAID enabled, it shows the IDE drive and 1 of the 2 SATA drives! i've been messing around the BIOS and all but no avail. any reccomendations?
2002 Chevy S-10 ZR2
Old 03-21-2006, 02:55 AM
circeseye's Avatar
circeseye circeseye is offline
im not sure if this will help BUT my comp is sata and when i upgraded i didnt know that each power cable is for a certain sata plug. sata 1 has its own sata power plug an so forth when i put mine in i pluged in sata 3's power plug with sata 1's connecter and got what you were discribing.
so i guess what im trying to say is try the different power plugs you might have pluged in the wrong sata power one.
i hope i made some sense of this kind of hard to discribe
Old 03-21-2006, 03:51 AM
mike1224's Avatar
not a whole lotta sense, but it gives me some things to try.
2002 Chevy S-10 ZR2
Old 03-22-2006, 08:32 PM
circeseye's Avatar
ill try again
lets say you have 4 sata slots and each is numbered
sata data plug 1
sata data plug 2
sata data plug 3
sata data plug 4
now the power also has 4 plugs also numbered
sata power 1
sata power 2
sata power 3
sata power 4
you have to use the data and power cables that are numbered the same.(some boards may not be numbered)
if you try to use sata data 1 and power 3 the drive will not work
i hopw this explains alittle bit better
