the dreaded brake/turn signal issue... possible fix
well i think i might have a easy fix for the melted bulb base on the rear brake/turn signal housing. I found a bulb called T3057 which doesnt have the plastic base but has the glass base from the bulb. So that should eliminate the melted base.
2000 Grand Prix GT w/ gold package. K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe 2004 Chevy Trailblazer EXT Keep on Keeping on... |
Re: the dreaded brake/turn signal issue... possible fix
BUMP, keeping this at the top. so far so good for a bulb not melting.
[quote=rubberman]well i think i might have a easy fix for the melted bulb base on the rear brake/turn signal housing. I found a bulb called T3057 which doesnt have the plastic base but has the glass base from the bulb. So that should eliminate the melted base.[/quote=bigredone]I had a problem with the brake lites (ABS and Traction lites coming on) and when I pressed the brake pedal both turn signal lights would light dimly and bulbs kept burning out. The plug to the rear assembly was burned. I cut of the tab from a soda pop can and jammed it in the plug. All brake lites work 200% and no more ABS and Traction Lites.
