Go Back   Automotive Forums Car Chat > Pontiac > General Discussion
Old 03-06-2006, 10:24 PM
haire_11 haire_11 is offline
MAP or IAC sensor?
i really need help here my cars rpms are surging between 750 and 1200 when i drive at 35 km/h or less until i come to a complete stop or press the gas, this only happens when the engine stars to warm up and happens all the time after that. also when i shift to neutral(auto trans) the rpms hang around 2000 for a few seconds and then go back down. i dont know if this helps but when i start the car the rpms shoot up to 2000 and then slowly come bask down to 900. its a 93 sunbird gt 3.1. another thing is the check engine light only comes on after its been ideling for a while . i just dont have enough money for trial and error .... so what ive learned so far is that its most likely the map but because the rpms go so high on start up im also thinking its the iac ... this problem is anoying as hell so help me please
Old 03-13-2006, 04:13 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: MAP or IAC sensor?
it could also be a vacuum leak.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-13-2006, 04:36 PM
yah ive been thinking that but there doesnt seem to be one
Old 03-13-2006, 04:43 PM
richtazz's Avatar
1st, pull the codes that the CEL is indicating are present and post them here. That will eliminate a whole lot of guessing.
Old 03-14-2006, 08:59 AM
3.1L 200+hp's Avatar
3.1L 200+hp 3.1L 200+hp is offline
Before you pull the codes im going to guess it is the Map sensor because when i had a little bit of an electrical fire thats what mine was doing when my Map sensor was bad(cooked)
Old 03-14-2006, 04:01 PM
maxwedge maxwedge is offline
A990 racer
Possibly he didn't have a fire and needs to diagnose what is actually wrong?
Old 03-15-2006, 12:06 AM
yah i dont have anything to check the codes so i guess ill have to get it done at the shop .... and one know if theres anywhere that'll do it for free in canada
Old 03-18-2006, 01:14 PM
turns out that both the MAP and IAC are gone i pulled the codes and got a 33(MAP) and 35(IAC) .... heres the how to i found on how to pull the codes using a paper clip http://www.v6z24.com/howto/codes its a great site with lost of how to's and a really good forum
