Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-06-2006, 07:46 PM
97gs-t teamrtv 97gs-t teamrtv is offline
Send a message via AIM to 97gs-t teamrtv Send a message via MSN to 97gs-t teamrtv Send a message via Yahoo to 97gs-t teamrtv
Power Steering Belt
My power steering belt is basically brand new from the mitsu dealer. When i start the car it squeaks loud enough to be heard 3 square miles away. Anyway its loud but a little less noticable when the car is warm. I hate belt dressing but i even tried it. The tensioner is as loose as possible but the belt still seems a little tight. I even took it off and compared it to another new one at the dealer. Im clueless. Maybe the power steering fluid.... Any suggestions welcome.
97 gs-t: Guages: boost, oil pressure and temp, water temp and volts. AEM cam gears, short throw shifter, hks ssqv, injen intake, brembo drilled rotors, akebono ceramic pads, sportline springs & koni ajustables, Strut bars: front, rear and lower rear tie bar. Evo III manifold and o2, megan downpipe, Apexi N1 catback, 16g, 190 fuel pump and FMIC.
Old 03-06-2006, 07:50 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Re: Power Steering Belt
Ummmm... it may not be your PS, check your altenator belt, check the altenator tself, if you see black shavings, thats it. It may be getting old, might need new belt or alt. or just tighten everything,
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 03-06-2006, 08:02 PM
All the belts were changed. Pretty sure its not the alternator belt. Did i mention when the sqeaking is happening, as i turn the steering wheel it gets louder. The car has to be warm for like 10 min then it will stop. On a humid day it dosent stop unless fully warm and going stright. Im tempted to cut the damn belt and go without.
Old 03-06-2006, 08:05 PM
MexRocket's Avatar
lol I didn't know it did that as you turned the wheel. Hmmmm I don't know muc habout PS, don't cut it lol I thought the PS belt also operates the Water pump
Old 03-06-2006, 11:42 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Your ps pump could be going bad, it could also be your water pump. Take the belt off and check to see if both turn relatively easily.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-07-2006, 12:20 PM
Water pump just replaced a few months back. i guess powersteering pump will have to be changed. anyone have a PS pump they are willing to part with?
