Old 07-02-2002, 11:00 AM
Phat_Si's Avatar
Phat_Si Phat_Si is offline
Send a message via AIM to Phat_Si
LS motor for me?
What would I need to put a ls motor in my crx??? and what are the average prices for these things?
-----'89 Crx Si-----
I/E
NGK plug wires
Custom backseat
Rims
clear corners
Awia head unit w/Pioneer speakers
Blowin' Smoke!
--Soon To Be--
slammed
new D16a6 block
sohc vtec d16z6 head, P&P'ed
gude stage 2 cam
gude cam gear
some fuel goodies etc...
Old 07-02-2002, 01:12 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
This is what I spent running non obd/97 LS motor/88 Civic DX hatch.
You can probably save on other parts and wiring, but this is what i spent.
97 LS motor $900
Y1 tranny $500
Stock clutch $150
Clutchmasters lightened flywheel $290
Hasport billet mounts $450
Shift linkage $150
Vtec wiring harness $250, preparing for lsvtec...$199 if just running LS
Exchanged stock DX harness from junk yard $75
new waterpump/timing belt/fan belts/radiator hoses $200
oil (synthetic)/oil filter/coolant/plugs/cap & rotor $150
clutch, throttle and speedo cables $150
91 teg distributor $150
91 teg injector plugs $20
injector resistor box $50
rear engine bracket $75
jdm 4-1 header (optional) $375
hks exhaust (optional) $400
intermediate shaft (91 teg) $75
axles (91 teg) $200
Labor: $700
Running total: $5310.00
* you can probably shave about $1000 from the total, if you pick your parts wisely..
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
