Old 03-06-2006, 05:52 PM
aj94z28 aj94z28 is offline
does anyone know how to program a stock keyless entry remote?
I need help. I have a 94 z28 that came from a salvage yard, and i ordered the keyless remote, but im not sure how to program it. can anyone help?
Old 03-06-2006, 07:21 PM
malletslinger's Avatar
malletslinger malletslinger is offline
Re: does anyone know how to program a stock keyless entry remote?
Usually, programming remotes has two steps:
The first can go one of two ways...there is eather a button to push on the module in the car or if there isnt one, you just disconnect the wires to the module, wait for like 30 seconds, then reconnect the wires to the module.
The second is to push a button on the remote itself.
That has been my experience with them...if someone knows specifics for this system, then Im shure they will chime in...
Old 03-06-2006, 10:31 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Programming procedure:
Ground the program input line by connecting a fused jumper at the Data Link Connector (DLC) from terminal "G" to terminal "A" (note: use terminal G and A for pre '95 12 pin DLC. A is the top right pin and G is the bottom left. Use terminals 4 and 8 for the '95 16 pin DLC. The 16 pin DLC connector is numbered top left (1) to top right (8) and bottom left (9) to bottom right (16) ). The Receiver will cycle the Door Lock Actuators within one to three seconds to acknowledge that the Receiver is in the "PROGRAM" mode.
Press any button on the Transmitter once. In response, the Receiver will cycle the Door Lock Actuators to acknowledge that a transmission has been received.
Press any button on the second Transmitter once. In response, the Receiver will cycle the Door Lock Actuators to acknowledge that a transmission has been received.
Remove the fused jumper from the DLC and verify system operation using all three Transmitter buttons.
Important
Always program both Transmitters when replacing a lost or damaged Transmitter. The first Transmitter Code programmed will always be in both memories until a second Transmitter is programmed within the same sequence.
The Keyless Entry System will not be operational if the program input line is left grounded.
Program only one vehicle Keyless Entry System at a time. If multiple vehicles are being programmed in close proximity simultaneously, it is possible that the same Transmitter could be trained to more than one Receiver.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
