Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-06-2006, 03:38 PM
rontomed's Avatar
rontomed rontomed is offline
Question Battery Terminal Corrosion.
I noticed my 1999 Ram 5.2 was showing a lot of corrosion on the battery terminals. I cleaned the cables and the battery posts with a water and baking soda solution and a tooth brush. Isn't there some kind of conductive grease that I can put on these terminals to slow down the corrosion?
Old 03-06-2006, 04:46 PM
crazys182003's Avatar
crazys182003 crazys182003 is offline
Re: Battery Terminal Corrosion.
http://www.kingsolar.com/catalog/mfg/other/g8.html
http://www.nocorrosion.com/boat-battery-corrosion.htm
http://www.efunda.com/Materials/corr..._corrosion.cfm
Old 03-07-2006, 12:30 AM
tony36 tony36 is offline
Send a message via MSN to tony36
Yes there is a grease and a spray, but it will do you little good now. to stop the corrosion you need a new posative cable. Once the corrosion starts it travels up inside the cable, then no matter what you put on it or how many times you clean it, it comes back. If you were to cut the insulation off you would see it all through the strands of cable. If you use the anti corrosion on new cable it makes it last much longer, but it is almost a waste to use on corrode cable
Old 03-10-2006, 01:21 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Pick up a set of these anti-corrosion washers at any auto parts store and they will help. If the cables are corroded bad, they should be replaced. If the battery is old, you may also be subject to more corrosion.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 03-10-2006, 07:20 AM
rontomed's Avatar
Talking Re: Battery Terminal Corrosion.
This is a top post battery, the cables are in excellent condition and the battery is only a year old.
Old 03-18-2006, 11:03 PM
shogun88888888 shogun88888888 is offline
dielectric grease, about a buck or two, will help keep moisture out and keep corrosion from forming. Wont fix a corroded cable but works real well. Use it sparingly on all electrical connections under the hood.
Old 03-19-2006, 12:14 AM
indyram indyram is offline
basically anything approved for electrical would work, as far as a grease. I wouldn't use a spray. the biggest thing is not too much, but enough to keep the air from getting to it, which causes oxidation, and thus corrosion.
