Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-06-2006, 02:52 PM
91Rodeo 91Rodeo is offline
BUCKING Rodeo
My 91 Rodeo (Manual 4WD) is bucking like a bronco as slow speeds. At idle it mostly lopes almost to teh point of stalling and then reves up adn later drops. At highways speeds it does okay, but always seems to want more gas. then when shifting at lower speeds, but at crising rpms it begins to buck or feels like it loses power unless I go above or below that rpm range. I've had most every sensor replaced or checked out ($1600 worth). My mechanic has checked out the Throttle Position Sensor and says it's within spec. . Any ideas?
Old 03-06-2006, 07:53 PM
rodeo02 rodeo02 is offline
Re: BUCKING Rodeo
Well.. I'm glad it starts with a "B". What engine? if it's the GM 3.1L, I'd check the MAP sensor (manifold absolute pressure). It's mounted on the air cleaner housing with a vac line & wire or two going into it.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-07-2006, 08:54 AM
Re: BUCKING Rodeo
Thanks for the quidk reply. It is the 3.1LGM engine. The mechanic has changed out the MAP sensor, O2 sensor, typical tune up stuff like wires, plugs, also computer,. Like I said, about $1600 worth.
Old 03-07-2006, 10:28 AM
Ramblin Fever Ramblin Fever is offline
Re: BUCKING Rodeo
FWIW - try changing gas stations if you use the same one all of the time; also, have you had your Cat Convertor checked out?
Also check for any kind of intake air leak; fuel filter, fuel pump.
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 03-07-2006, 10:35 AM
Re: BUCKING Rodeo
This is a tough one being that we don't know if this is fuel or spark related. Has the ignition module/coils been looked into?
Joel
