Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 03-06-2006, 03:40 PM
kyle_1500 kyle_1500 is offline
Question buzzing noise from heater?
my 1989 GMC k1500 stepside makes a buzzing noice when i run the heater, when i turn it up the noise gets louder, whats causing this and how do i fix it?
Old 03-06-2006, 04:11 PM
2000CAYukon 2000CAYukon is offline
Re: buzzing noise from heater?
Could you be more specific? Does the noise get louder when you change the fan speed? Or is it when you adjust the temperature for more heat?
//2000CAYukon
Old 03-06-2006, 05:54 PM
Bob B Bob B is offline
Could be some leaves or like in my case, pine needles get in there and ratchet on the blower cage.
Mine eventually ground away.
Bob B
Old 03-08-2006, 10:16 AM
Marsal420's Avatar
Marsal420 Marsal420 is offline
Send a message via AIM to Marsal420 Send a message via Yahoo to Marsal420
Exclamation Re: buzzing noise from heater?
Yeah my 1994 Gmc Sierra does the exact thing when i turn the heat to a higher speed. I dont hoenstly know what it is and i havn't checked if there were anyting stuck in the cage but i will. Hopfully someone knows what may cause this i though it could just need oiling? But i dunno gotta wait to summer to find out.
I NEED HELP TOO!
Old 04-11-2006, 11:08 PM
IHPk IHPk is offline
I had a 2000 GMC Sierra that had the same problem. It turned out to be a really dirty "cabin filter" was causing the fan to make the noise due to strain. Don't know if your year truck has a "cabin filter" but if it does, change it out and I'll bet the problem gets solved.
Old 04-12-2006, 12:54 AM
I had a leaf get down into the cage and it made a lot of noise. I pulled the blower motor and cleaned out the leaf.
No cabin air filters until 99 NBS.
//2000CAYukon
The Following User Says Thank You to 2000CAYukon For This Useful Post:
casserole30 (07-31-2014)
Old 07-31-2014, 08:16 PM
casserole30 casserole30 is offline
I have a 2000 GMC sierra 1500 and I have heard that same humming noise while the heat or A/C was on. The noise also got louder when i turned the dial to a higher speed. So I took the blower motor out and found 2 leaves in it. Then I took the leaves out then put it all back together and it works perfectly. I hope this helps somebody because I was very frustrated with it. Thanks
