i need fuel pump help!
ive got a 92 lumina euro 3.1 engine and i need help or info on getting the fuel tank dropped because i can't get to the strap bolts and was wondering if i had to take something else off so i can get to the bolts. if somrone else has dropped a tank please tell me how u did it.
Re: i need fuel pump help!
Go to autozone.com/repairinfo for instructions
hey bro
the front bolts NOT the rear bolts witch are hiddin by the rear suspention The front left is by the fuel filter the hose can be pushed outa the way THE right passenger side bolt you must remove that heat shild and pull thoes 2 rubber exhuast rings and u'll see the bolt the tank straps are 15mm AND exhuast heat shild is 8mm just remember theres 7hoses 2bolts 2smaller bolts 2rubber rings 1 electrical connector the front 3 hoses "fuel filter, Return line,Vent hose are at the front there at the back theres the filler neck hose and a main vent hose above at top of tank 2 smaller lines for ur emissions can Brad sorry for the vag dicription But l just did mine 4times if ur pump died when tanks full be very carfull that tanks very odd to find its center of gravity and when reinstalling remeber when ur bitching why the front bolts wont go in rember to have the rear of the tank suported pushed up all the way After you reconnect the hoses |
thanks for the info i was starting in the wrong spot thats why it was so hard i'll reply again later.
