89' Daytona Heater Fans...
Hey Everybody, I was just thinking, since im not a big car guy, I was wondering how I would go about fixing the fans up by the dash. The dfroster and lower ones work, but the bi-level(middle) fans wont work, Am I going to have to tear the dash out to fix it? Thanks!
Re: 89' Daytona Heater Fans...
Theres only one fan which comes out under the glove box. But your fan is ok if you are getting air. Your problem is with the doors that port air to the different outlets. Could be a vacuum leak going to one of the doors. could be the control unit where you select the bi-level, defrost etc. butons.
andy
Andy Cincinnati Ohio 85 Dodge Lancer 618,825 miles Turbo II 87 Shelby Lancer w/ hybrid '90 2.5L and 16 valve 2.4L head , Intercooled turbo, A568 5speed 91 Dodge Spirit R/T 2.2L Lotus 16v 91 Dodge Shadow Convt. 2.5 NA 96 Dodge Grand Caravan ES 3.8 02 PT cruiser (w/ fake Chrome wheels) |
Hey,
Yea, There is a selector for bi-level, defroster, fan, and stuff like that, but when you click any of them, it doesnt switch over like it is supposed to...Could the switch be bad? Justin |
yes the switch control could be bad. If you are hearing nothing when various buttons are pressed then check the vacuum supply line in the engine compartment. There is a small gray plastic line running from the brake booster to the fire wall. This is the line that supplys vacuum to the control unit.
make sure it is connected to the brake booster and not cracked. Good luck andy
Hey Andy,
Alright, Ill try that tonight and reply to what goes on, Talk atcha l8r or tomorrow Justin |
yep, it was the switch...Figures... something so big happens with something so little...man..thanks for the help andy.
-J |
