Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 03-06-2006, 12:01 PM
Krystal Krystal is offline
Send a message via MSN to Krystal
Angry 93 Galants Starts but won't go!!
I need some opinions....I have a 93 galant with an automatic transmission..the problem, i was driving home and stopped at a stop sign, when i took of it was like someone shifted the car into neutral Now the car just revs. It starts FINE and there aren't any noises, but it just won't shift, its like it is stuck in neutral. I just had all of the belts replaced. I need all the suggestions I can get. I miss my car!
Krystal
Old 03-12-2006, 09:54 AM
Bronxbombr Bronxbombr is offline
Re: 93 Galants Starts but won't go!!
Its time to say goodbye to the tranny for it is done for.
Old 03-26-2006, 09:02 AM
tennadian tennadian is offline
Have someone check the transmission fluid, (unless you already know how). It's possible you may have a leak, and lost just enough fluid for it to slip. If so, add some more and try it. If it works, take it to the shop to find and fix the leak. If not, like the other post, you will need a new or rebuilt tranny. Good Luck!
Old 03-30-2006, 07:26 PM
Re: 93 Galants Starts but won't go!! updated 3/30
I had a friend tell me that the problem could also be CV joints. Does anyone agree/disagree with this option? Please let me know.
Old 03-30-2006, 11:59 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
If your tranny is in that bad of shape you should call a mechanic. More than likely they wont charge you if you just give them the details and ask for some suggestions. And if they want to charge you I'd call another mechanic because most would have no problem with a quick phone call for some simple advice or suggestions of what it may be.
Old 05-04-2006, 09:13 AM
So my dad just realized....You can shift the car, but it just won't move. The motor will rev and everything. You can put it in park and it won't move, put in reverse, puch it backward, neutral okay well y'all get the point... So now I am asking again.....PLEASE HELP, I don't really want to take it to a mechanic if there is no hope!!!!! I will take any suggestions/help
Krystal
Old 05-14-2006, 11:06 PM
eman_226 eman_226 is offline
yeah, i have the same problem...won't go in any gear....it will drive in the '2' gear but will go 15 mph max... i'm thinking the tranny is gone...
