Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-06-2006, 09:33 AM
mtcs's Avatar
mtcs mtcs is offline
Send a message via AIM to mtcs Send a message via MSN to mtcs
Arrow Low RPM problem/stalling
When I disconnect my battery to do maintenance on the electrical system or on my system, when the battery is reconnected I have problems with low RPM. When I reconnect the battery everything seems ok. I know that when you disconnect your battery, your throttle positioning snesor resets itself and it t akes a little driving before the RPMs are what they should normally be. It has happened to me a few times and each time the car stalls at lights because the TPS wasnt finished resetting itself. That isnt the problem. THe problem is that just reciently, it has taken a lot of driving to get it to reset. The last time it did it to me, it took me an hour and a half of driving before it stopped stalling at stops. Is this normal? or is there some problem with my TPS?
Old 03-06-2006, 10:33 AM
95_GSX's Avatar
95_GSX 95_GSX is offline
Send a message via Yahoo to 95_GSX
Re: Low RPM problem/stalling
When your battery is disconected for more than 15 minutes your ECU is cleared. So any adjustment to timing curves and the like are cleared with it and yes it could take up to an hour or so to get all those adjustments back. I'm not saying that this is your problem but it could be a possibility. When was the last time you did plugs and wires???
Got AWD?
Some people buy super cars, other build them
----Click It, For Mods and Pics----
'95 Mitsubishi Eclipse GSX - For Sale
'05 Volkwagen Golf GLS TDI - My daily driver
'03 Ford Excursion 6.0L PSD 4x4
'13 Ford F150 FX4 SCREW 4x4 3.5L EcoBoost
'08 Buell 1125R
'83 GMC Sierra Classic K2500 4x4 - Future Cummins Swap
