Old 03-06-2006, 09:01 AM
Twilight_Sorcerer Twilight_Sorcerer is offline
Heating Control System
I have a 93 Lumina, heating control system has gone odd for lack of a better term. When I try to change the location of where the heating system is going it only will run to the floor and window, when I try to change speeds it will only run at high, no other settings work. I have checked fuses and connections and all seems to be in order. Anyone who can give feedback would be appreciated as I love this car. 3.4 Euro model. Btw, other question if anyone can answer it. The brakes on mine are funny as I have heard from a few others that this is normal for this car. Has anyone upgraded to some other types of Pad and Rotors and does it solve the problem. Generally when I am braking it yo can feel the resistance pulsing as the brakes are running.
Thanx
Brian
Old 03-06-2006, 01:29 PM
Myxlplyxxx Myxlplyxxx is offline
Re: Heating Control System
Well Id take a solid guess that your resisitor has gone south... mine was the same way so replaced it(0n my 97 its up under the dash behind glovebox) and the window/floor prob sounds like a vacuum leak... trace the lines off the upper intake... there is a "T" connector that usually goes bad.... like mine did but also could be a crack in 1 of the lines also.... hope it helps... good luck
MYX
Old 03-06-2006, 05:46 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
YEp, exactly as Myxlplyxxx said, the blower stuck on high is the blower resistor, and tbeing stuck on 1/2 defrost and 1/2 floor is a vacuum problem. The mode actuators are controlled by a vacuum solenoid under the dash near the glove box. When you set the switch to the various positions, it sends a signal to the solenoid to move the various motors/actuators. Some of the actuators are direct vacuum controlled, others are electrical and are sent an electrical signal from the vacuum solenoid.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
