Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 03-06-2006, 08:33 AM
Powelly Powelly is offline
Fuel Starvation Problem Please Help!
Had my car around 3 weeks and already it's playing up!
For some reason around 4-5,000rpm the car is bogging down and losing power until it settles around 1,000rpm.
It's not throwing any codes up, had it on the rolling road which confirmed it's running nearly 100% lean when bogging down.
Suggestions include: O2 sensor, vacuum pipe blocked?, fuel pump?
Have changed the fuel filter, plugs, leads all last weekend which have not improved anything. Run Red-ex fuel & injector cleaner through it twice.
Checked the voltage readings from the sensors which seemed abit high but no codes being chucked up.
Seems to run fine after you fill up with petrol for around 5 mins then back to bogging down. Even tried running it without a fuel cap but no good.
Really am down in the dumps and not even Honda can help with this one
Any ideas or suggestion are most welcome
Thanks you all!
Old 03-06-2006, 08:37 AM
Re: Fuel Starvation Problem Please Help!
Forgot to mention
1994 Honda Civic SIR EG6
B16a Engine
Supersprint Manifold & Exhaust System
Carbon Air intake with Cotton Green Air Filter
Standard ECU
Old 03-13-2006, 11:49 PM
blitzcivic's Avatar
blitzcivic blitzcivic is offline
it sounds like you may have a bad injector. i would pull them and have them cleaned and tested. it happen to a customer of mine
1993 HONDA CIVIC EX
BLITZ FRNT M3 SIDE BLACK WIDOW REAR
JSP TERMINATOR WING
17' MOTEGI SUPER SILVER RIMS
D16Z SOHC 1.6 VTEC
SKUNK2 INTAKE MANIFOLD
CROME TUNED ECU
B&M FUEL REG
DSM 450CC INJ.
MSD BLASTER COIL
APC 9MM WIRE
GREDDY BACKCAT EX
T25 CUSTOM TURBO KIT @ 7PSI
TUBULAR MANIFOLD
AIR TO AIR INTERCOOLER
ALCOHOL INJECTION
18002 TURBO MILES AT 218002 MILES GOING 140MPH FINALLY WENT
BUT, STILL GOT ME HOME
