Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-06-2006, 06:08 AM
Wolfy_Suburban Boy Wolfy_Suburban Boy is offline
99 Suburban - Blower Motor Speed Selector Switch
I've got a 1999 Suburban that I've had to replace the blower motor speed selector switch for the third time. The first time I replaced the switch the vehicle had over 60,000 miles on it. The switch was melted around the contacts. The next two went out within the next 10,000 miles. The replacement switches work fine for awhile and when they start to go the start working on an intermediate basis. Can the quality of the replacement switches really be that bad or is something else causing them to fail. It never blows a fuse either.
Also, how do I use the search feature for this forum?
Thanks for your help,
John
Old 03-06-2006, 08:32 AM
bpalmer bpalmer is offline
Re: 99 Suburban - Blower Motor Speed Selector Switch
As far as the heater switch goes I had the same problem on my 99 (melted contacts). Once I replaced with a AC Delco, the problem went away. I had a similar problem with a Wells (autozone) distributor cap; left me on the side of the road. I have learned the hard way that although the quality of the parts originally put on these trucks is marginal, I'm better off buying Delco replacement parts.
As far as searching goes, once you logon a search option will appear at the top of the thread (not top of page). Type in a few words and let it rip. Advanced searches work as well. Hope this helps.
Old 03-08-2006, 08:39 AM
The last two switches were A/C Delco switches. It's got to be something else that is causing the switch to go bad and cause an intermittent function. Any other suggestions?
Old 03-08-2006, 04:21 PM
Old Dave Old Dave is offline
Sounds like you have a loose connection on one or more of the wires on the plug. Loose connection= heat.
1970 GMC 2WD shortbed fleetside
1984 Olds Delta 88 (won't die)
1997 GMC Suburban K1500 W/5.7L Vortec
2000 Dodge Ram 1500 4WD Shortbed Ext. cab
1998 Chevy K2500 W/5.7L Vortec
2002 Harley Custom Chopper
Wife is a late 1951
Old 03-08-2006, 05:22 PM
777stickman 777stickman is offline
Other components in the system are the resistor pack for the 1st 3 blower speeds, the "high" speed relay, the blower motor itself and the wiring.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-09-2006, 02:38 AM
Thanks Guys! Looks like I've got some digging to do; I hate those electrical gremlins!
Old 03-09-2006, 06:04 AM
Now I remember having to replace the pigtail as well as the switch. There was a loose conection that caused the short. I still can't get used to having to replace pigtails; shouldn't they last forever? Hope this helps.
Old 04-03-2006, 12:41 PM
Smile Re: 99 Suburban - Blower Motor Speed Selector Switch
It turned out to be the main power terminal was starting to slip out the back side of the fan switch. It was arcing across which made it work periodically, but never blew a fuse..only melted a few switches. I was able to save the terminal and my Suburban is blowing strong once again! Thanks for the help crew!
Wolfy
