Old 03-06-2006, 01:40 AM
adaly86 adaly86 is offline
oil under engine
Hi, I have a 91 Civic and my dad had been driving it for awhile and now i have noticed a small pool of oil under the car just under the oil sump but the oil does not seem to be leaking from the engine its just on the bottom of the oil sump, there is also slightly too much oil in the engine, where could this oil be coming from?
Old 03-06-2006, 06:24 AM
Hybrid1990crx's Avatar
Re: oil under engine
can you use a different word other than sump? Do you mean the oil pan? If so check your drain plug.
Old 03-06-2006, 03:25 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
A sump is a lower collection point, where a liquid will run to, so yes that would be the oil pan.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-06-2006, 07:00 PM
skotman's Avatar
skotman skotman is offline
mine does this too. i just figured it's old age.
or a gasket.
or several gaskets... 16 year old gaskets...
it's been doing that since i got it (3 years) and i haven't done anything about it other than check my oil regularly (because i burn oil too) and change my oil regularly.
when i've got money (time, rather) for an overhaul and new gaskets, i'll get right on it.
Old 03-08-2006, 04:31 AM
Ok thanks, I dont really use it that much so i dont think it would get a chance for the oillevel to really get too low!
Old 03-08-2006, 06:11 AM
my motor doesnt leak a drop of oil
