Go Back   Automotive Forums Car Chat > Nissan > Prairie | Liberty | Axxess | Bassara
Old 07-01-2002, 11:12 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
Bassara Specs
It came with 3 different engines:
YD25DDTi (diesel)
VQ30DE
KA24DE
SPECIFICATIONS OF THE BASSARA Grade X (2WD Gasoline2400 E-AT)
Overall Length (mm) 4,795
Overall Width (mm) 1,770
Overall Height (mm) 1,725
Wheelbase (mm) 2,800
Tread Front (mm) 1,535
Rear (mm) 1,520
Ground Clearance (mm) 155
Curb Weight (kg) 1,610
Turning Radius (m) 5.7
Steering Rack & Pinion with power assistance
Suspension Front Ind., struts
Rear Multi-link beam
Brakes Front Ventilated disks
Rear Leading-trailing
Tires Front 215/60R16 95H
Rear 215/60R16 95H
Engine Type KA24DE DOHC, 16-valve In-line 4
Displacement (cc) 2,388
Bore x Stroke (mm) 89.0 x 96.0
Max. Power (kW[ps]/rpm) 110[150]/5600
Max. Torque (Nm[kgm]/rpm) 216[22.0]/4400
Compression Ratio 9.2:1
Induction EGI(ECCS)
Transmission
Electronically controlled 4-speed Automatic Transmission
Gear ratio
1st 2.785
2nd 1.545
3rd 1.000
4th 0.694
5th -
Reverse 2.272
Final 4.425
Information found at
http://www.nissan-global.com/GCC/Jap...991104_0e.html
Old 10-18-2002, 04:35 AM
Ssom's Avatar
Ssom Ssom is offline
Send a message via ICQ to Ssom Send a message via AIM to Ssom
yeah......But what does it look like???
Old 08-05-2004, 03:05 PM
CaTasHtRoPhE 67 CaTasHtRoPhE 67 is offline
Re: Bassara Specs
i wanna see what this thing looks like
Old 11-22-2005, 02:08 AM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
http://media.idleriot.com/videos/fd7...26415b264d.wmv
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
