Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 03-05-2006, 02:20 PM
Marsal420's Avatar
Marsal420 Marsal420 is offline
Send a message via AIM to Marsal420 Send a message via Yahoo to Marsal420
Rear Differential
I own a 1994 Gmc Sierra and was looking to get a rear differential for my truck. I was told that i could weld the *Spider Gears* thus locking them and saving me alot of money. I dont really know much about this considering i dont see why i would do that and most likely it would break. If anyone has ever heard of such things please let me know.
And im open for suggestions.
Thanks
Old 03-06-2006, 01:08 AM
JaVeRo JaVeRo is offline
Re: Rear Differential
That would work if you NEVER plan on getting that truck on hard pavement again. I wouldn't ruin a good axle in a truck you drive every day.
James
Old 03-06-2006, 10:05 AM
maxwedge maxwedge is offline
A990 racer
Question Re: Rear Differential
Thanks
Not clear here, you have a rear diff., what are you trying to do?
Old 03-09-2006, 01:09 PM
mustangman02232 mustangman02232 is offline
Send a message via AIM to mustangman02232 Send a message via MSN to mustangman02232 Send a message via Yahoo to mustangman02232
i think he wants a limited slip
2004 F350 6.0 4x4 auto SRW
SCT X3 with innovative tunes, autometer boost/trans/pyro, AFE stage 2, MBRP 4" no muffler or cat, EGR delete, ARP studs, 8' fisher MM2, misc appearance
90 F350 7.3 IDI 4x4 SRW (sold)
bolt on 02 mustang 232 4R70W vert (sold)
built 88 toyota pickup (sold)
bolt on 92 camaro LO3 TBI (sold)
Old 03-11-2006, 02:48 AM
strmn94's Avatar
strmn94 strmn94 is offline
Thanks
first, you do not want to weld the gears together. it will weaken the gears, and it will make it very hard to turn corners.
what you want is either a limited slip carrier, which has clutches in it, with springs and spider gears. it allows slipage so you will be able to turn corners.
the other option is a locker spool. this unit is like a straight axle, it will let you turn corners, but it will make a clicking noise as you turn.
it uses springs, and the 2 halves have large teeth that interlock together, and will come apart to allow a small amount of slippage.
yes both options cost money, but welding the spider gears together will end up costing you alot more when they break and damage the ring and pinion gears.
