Old 03-05-2006, 01:54 PM
Raynman Raynman is offline
Question Brake lights not working
I recently purchased a 1991 ext cab. The problem is that the brake lights do not work, but all others do. I checked fuses and even pulled the switch out from under the pedal and checked it with an ohm meter. Seemed to be in working order. Any and all advice would be appreciated. Thanks
Old 03-05-2006, 06:26 PM
777stickman 777stickman is offline
Re: Brake lights not working
Raynman: Welcome to the forum. When you say all the other lights work, are you saying the rear turn signals and the rear flashers are working? How about the 3rd brake light(if installed)? The circuitry for the left & right brake lights goes thru the turn signal switch and the 3rd brake light does not. Good job on checking the stop switch. That will eliminate it. Let us know........Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-05-2006, 07:36 PM
It does not have the third brake light option. Emergency flashers, turn signals, back up lights, and running lights all work
Old 03-05-2006, 10:06 PM
mbumgua's Avatar
mbumgua mbumgua is offline
Sounds like the brake switch may not be adjusted right-if it is not adjusted right the brake lights will not come on-search this forum--there are good instructios on how to here.
Old 03-06-2006, 06:17 AM
The switch is fully extended when the pedal is depressed. I don't believe the switch to be my problem, as much as I think its electrical.
Old 03-06-2006, 09:47 AM
My'98 manual shows a "stoplight relay" in the underhood fuse block on pickups only. Not sure if your '91 has one. Otherwise you'll have to start checking for power into and out of the turn signal switch.
57 Chevy 210
Old 03-07-2006, 07:14 AM
blazin84 blazin84 is offline
Try and pull your tail lights out, there is a circuit board that the lights plug into. Somtimes moisture gets in there and corrodes the board. But this may not be the case if it is just your brake lights that arn't working. Worth a try though i guess.
Old 03-07-2006, 07:32 PM
broughy84's Avatar
broughy84 broughy84 is offline
true, but if the brake lights don't work and the turn signals DO, I don't think it would be the board, as they are the same light bulb....check the switch for continuity and for 12V+, also check the stop lamp fuse, on a 91 I don't believe there is a stop lamp relay, but I may be mistaken.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 03-08-2006, 07:57 AM
Thumbs up Re: Brake lights not working
I'd like to thank everybody for their help. It was only after I located a Chilton manual that I understood the whole turn signal switch thing. Turns out the wire for the brake lights had corroded and fallen out of the harness. Simple fix made easier by your help. Again, THANK YOU!
Old 03-08-2006, 09:39 PM
Lock_Up Lock_Up is offline
Send a message via AIM to Lock_Up Send a message via Yahoo to Lock_Up
i had the same problem with my 94 sierra...it just turned out to be one of the break lights was burnt out...so check those...its worth a shot.
