Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-05-2006, 12:04 PM
Clarke08 Clarke08 is offline
Clutch Problem 99 Sunfire
Im getting a clunking noise when pushing in on the clutch and it ingages way earlier than before. Is it fuked or can a simple adjustment be made to fix this?????
Old 03-05-2006, 06:01 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Clutch Problem 99 Sunfire
Welcome to AF!!
The clutch on your car is hydraulic and it is very possible that the slave cylinder is going bad causing it to engage prematurely. There really aren't any adjustments on a hydraulic clutch so you need to investigate a little bit further.
Of course it is possible that the clutch is starting to go bad and is grabbing causing it to engage prematurely.
Old 03-05-2006, 06:24 PM
I had a brand new clutch put in 2 years ago when the transmission was rebuilt so I hope It is not the clutch lol. There is a power train warrenty on my car with 2 months left that covers the Case, all internal parts, torque converter, transfer case, vacuum modulator, transmission mounts, seals and gaskets. Do you think it would covered under this ??
Thanks.
