Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 03-05-2006, 10:46 AM
POPPABUSA POPPABUSA is offline
02 Bravada 4wd Smarttrak not working
My wife found out the hard way that the Smarttrak 4wd system is not working on our 02 Bravada. On Tuesday, she spun out and ran off the road in snowy conditions. When she tried to get it unstuck, she noticed that the front wheels were not spinning. I have since tested it on other snowy roads, and the front wheels do not kick in. I have checked the fuses, and wiring around the transfer case, but have not found anything unusual. No idiot lights on the dash have turned on. What should I be looking for? Possibly a problem with the transfer case motor? If so, how do I test it? Any ideas?
Old 03-05-2006, 03:25 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 02 Bravada 4wd Smarttrak not working
You might try spinning the rear wheels just a few more times in hopes the trouble light will come on. You can get the computer checked for pending codes at some chain type auto parts stores.
Please excuse this statement, but I'm sure you know some '02 Bravadas were built without AWD. They have no front differential or axle shafts.
Old 03-05-2006, 06:06 PM
I will try that. It is AWD, it does have a front drive shaft, differential, etc...
Old 03-07-2006, 03:38 PM
Exclamation Re: 02 Bravada 4wd Smarttrak not working
Took the 02 Bravada to a local shop today. They scanned it , came up with no codes. They did put it up on a hoist, and ran it at about 20 mph, up off all 4 wheels. The front wheels started spinning, but were weak. They said they could stop the front wheels with their foot pressed on the wheel. They recommended another shop. Any ideas?
Old 03-12-2006, 11:30 PM
AF - Advisor
I think there's an electromagnetic clutch inside the transfer case. If the coils burn out or go to ground, you should get a code of some kind but if the clutches are worn out and slippage occurs, I don't know if you should get a code for that slippage. I know you'll get one for a transmission component slippage.
Old 03-13-2006, 09:05 AM
Took it to the dealership. They said the transfer case control module needs to be replaced. $475. We will see what happens next...
Old 03-13-2006, 02:43 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
wow, $475? might want to check with the wrecking yards and see if you can save a few bucks for retirement.
Old 03-13-2006, 03:49 PM
AF - Advisor
Is that the piece they call encoder motor?
Old 03-14-2006, 02:19 PM
Lightbulb Re: 02 Bravada 4wd Smarttrak not working
I believe the transfer case motor is also referred to as the encoder motor. I ordered the transfer case control module from a dealership online for $173 shipped ( the cheapest I could find). I hope to have it in this weekend. I think it is located behind the dashboard on the left side. Hopefully it goes well. I will keep everyone posted...
Old 03-14-2006, 03:47 PM
AF - Advisor
OK, the module. Hope it solves the problem.
Old 03-18-2006, 08:15 PM
boldsmobile boldsmobile is offline
Control module is behind the kick panel on the passenger side.
Let me know how you make out with it. Usually a bad module with give you a code.
Peter Ferraro
1998 Bravada
1996 Aurora
1971 Cutlass
Old 03-20-2006, 10:55 AM
Replaced the module - no luck. Back to the dealer on Wednesday. Maybe the module has to be programmed???
