I just bought my first bronco, 1993 w/ the 5.0. When i bought it the idle would fluctaute b/w 1000 and 1400 RPMs. I just replaced the tps and it seems to have helped a little, however sometimes it is hesitant to accelerate when I "step on it" or it even just bogs down. Also when I put it in gear (E4OD tranny) the RPMs drop and it almost stalls unless I give it some gas. I am going to run some fuel system/injector cleaner through it but w/ my luck that won't help. Oh, and the cat. converter air tube is rotted off, I have a new one that I'm going to put on but I'm not sure if that will help anything. Please help me asap! Thanks
Re: Help! 93 Bronco 5.0 - hesitant accel. and high/fluctuating idle
the new cat will help immeasurably. Looking at the design of the internal combustion engine-it's built upon the backpressure of the exhaust system. The Catalytic Convertor is designed to build up and clog. After a decade or two, you'll need to replace it. It's probably what's choking your engine out. The Rot is a good sign that it's doing it's job, since your engine exhaust collects a lot of moisture.
I replaced the cat, converter air tube today and it did help w/ the hesitation and cure the exhaust leak I could hear, so now I suppose I can start looking for a new cat.converter. However one problem seems to leak to another!I'll mention that in a new post. Thanks for the help.
Have you replaced the Air filter (in the breather box?) One of those, and a new PCV valve will probably help it breathe. (Most Fords lope in the idle somewhat-but it's a sign that something is holding up the process...) If you've already taken a look at the backpressure, it's time to look at the 'front-pressure'-like the Air Filter, and PCV valve. (The PCV is the tube that runs from the valve cover to the breather box.)
Should have bought a Chevy... Hey, see if Garys U Pull It will give you like $100 dollars for the whole thing. And then maybe you can find a Eagle Talon TSI to fix up or something.
As a wiseman once said - " My lugs nuts require more torque than your Honda makes!" Fuck the fast and the furious, Ride slow and luxurious
Welcome to the boards friend. I haven't been very active lately but a good place around here is the Cars in General section. Theres a lot of cool stuff there.
