Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 03-04-2006, 06:59 PM
RLT RLT is offline
95 Aurora - High Mount Brake light Not Working
Someone mentioned to me this week that my high mount brake light was not working. No big deal, just a burned out bulb I assumed. Well, I replaced the bulbs (two bulbs) and it still does not work. The sockets look fine, no corrosion. The wiring that I can see looks good. I used a volt meter & found I'm getting no juice at the socket . . ? I did a quick search on this forum but didn't see a similiar scenario/solution. Is there an in line fuse or something else simple I should check. I'm thinking this should be an easy fix & am frustrated I can't figure it out. Any help greatly appreciated. By the way, my lower brake lights are working fine.
Rob
Old 03-05-2006, 10:22 AM
RLT RLT is offline
Re: 95 Aurora - High Mount Brake light Not Working
Well, after pulling apart a few things I found the culprit & easily solved my problem. The wire bundle leading from the high mount brake lights plugs into a connector behind the upper back seat -- near the top of the seat on the passengers side. The connector was unplugged.
I had some work down a few months ago & I'm guessing the mechanic took out the rear seat and the connection came free. In fact, as you work to replace the seat back I can see how the wires might get snagged & the connection pulled apart.
I hope this info helps someone in the future . . . This is a great forum, I don't have many occasions to post info but have sure learned a great deal by being a regular reader. Many thanks to all the contributors.
Rob
Old 03-01-2013, 05:45 AM
ABPcolumbus ABPcolumbus is offline
Rob,
How do you get to the high mount brake light to replace the bulbs? I've got a 97" Aurora with one side of the high mount brake light burnt out.
Thanks,
Tony
Old 03-01-2013, 02:00 PM
peeweewasblue peeweewasblue is offline
The original post is really old but here is the answer to your problem.
In the trunk under the brake light area there is a plastic panel. Remove the push pin clip on the passenger side and rotate the cover out of the way. The light sockets are twist in type mounts.
The Following User Says Thank You to peeweewasblue For This Useful Post:
ABPcolumbus (03-01-2013)
