Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 03-04-2006, 06:46 PM
mbrown1630 mbrown1630 is offline
Send a message via Yahoo to mbrown1630
will not keep running
I have a 1987 190E 2.3 that will not keep running on its own. The compression is good. I changed the fuel pump and filter, throttle body, inj fuel distribiter, injecters and spark plugs, distribitor cap, rotor button and sparkplug wires. I can,t get it to go past 4000 rpm,s and it won,t keep running unless i keep the gas pressed down. Can someone please help with me with this.
Old 03-18-2006, 11:55 AM
dave_rose69 dave_rose69 is offline
Re: will not keep running
Check your sparks color. If its redish brown, change your ignition coil. Bet my bottom dollar, your coil has went south, and this has been your problem from the beginning. The only other ideas IMO are: fuel pump pressure, fuel delivery pressure at the fuel distributor inlet, (use "T" fitting), OVP relay, or crankshaft position sensor.
