Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 03-04-2006, 05:09 PM
mike66109 mike66109 is offline
Exclamation 92 3.0 dead on road
driving down road heater core was leaking not really running hot was burning up alot of water and all of sudden died thought the timming sliped put new timing chain on new plugs no compression no start please help.
Old 03-04-2006, 06:42 PM
Crasen Crasen is offline
Re: 92 3.0 dead on road
if you have no compression in any of the cylinders I would think that the timing belt is still off, have you checked to see if the valves open and close when you crank the engine?
Old 03-05-2006, 06:11 AM
juliuszx6 juliuszx6 is offline
If you were burning water and have no compression you may have blown a head gasket.Is there water in your oil?
Old 03-05-2006, 10:14 PM
no water in oil.burnt plastic smell coming from floor board.no start wandering if a module burnt out or somethging. replaced timing was a little sloppy but not to bad still no start. please help.
Old 03-06-2006, 10:42 PM
Ok now what makes you say you have no compression? If you have no compression that is where your problem is. You need a spark, an air/ fuel mixture and compression for the engine to run, one of these is missing. Check for spark, fuel and compression and go from there.
