Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 03-04-2006, 01:56 PM
Ukrainian Ukrainian is offline
clear corner lights
hi!
could anyone explain how to put in clear corner lights on my 2000 323i....cuz i simply cant take the original ones out(dont wonna brake anything....trying to be gentle,but cant make em pop out) ....PLEASE HELP!!!
thanx guys!!!!
Old 03-05-2006, 02:17 PM
gth.berg gth.berg is offline
Re: clear corner lights
All you need is a long flat head screwdriver. There's a small oval shaped hole behind the corner lamp. Insert the screwdriver in there and press down the plastic tab on the back of the lamp. Then you basically pry the lamp out the front. If you've never taken them off before, the rubber strip around the lamp is probably stuck to the paint. It feels like you're going to break it, but as long as you've got the tab pushed down, you won't. You've just got to break the seal between the rubber strip and the paint. Good luck with it. The clear corner lamps will be a small touch that does wonders for your car.
