Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 03-04-2006, 10:27 AM
3GgtGirl09 3GgtGirl09 is offline
Send a message via AIM to 3GgtGirl09
Engine Shakes
My 2000 Eclipse GT has been sitting in storage for about a month. Yesterday I decided to take it out for a ride. I noticed that when I turned the ignition off the engine shakes. Does anybody have a clue as to what it could be and thoughts and ideas on the topic would be greatly appreciated.
Old 03-04-2006, 03:08 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
Re: Engine Shakes
motor mount? might one be broken or torn...
other than that... not much causes vibration unless it something is out of balance
Don't act like you don't love it.
503/2000
Old 03-04-2006, 07:09 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Re: Engine Shakes
How high were your RPM's when you shut off the engine. If your car is reving when you shut it off the engine will shutter, or if your idle was a little high it will do this. If your car hadnt been driven in a while it may have been ideling high simply because it was getting used to running again. Make sure you put a fuel stabilizer in if you plan on storing for a while, or you will run into some engine problems associated with bad gas. Other than that, and what Elchico said, idk
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
