Old 03-04-2006, 08:35 AM
KaverL KaverL is offline
Mitsubishi GTO
First off we go to a little paint problem.. I built a subaru WRX, and the paint was shiny and glossy, but when i added clear it became all nudgy, now why did it do that?
Before:
After:
Back on track, the GTO is by tamiya, i painted it red, but its drying right now, so no pics. But i did make the rear suspension. =)
Heres the kit:
And heres the suspension:
Old 03-04-2006, 09:29 AM
cham2020's Avatar
cham2020 cham2020 is offline
Send a message via ICQ to cham2020 Send a message via MSN to cham2020 Send a message via Yahoo to cham2020
Re: Mitsubishi GTO
ok
about the subaru.....what was the condition when you sprayed the clear coat. you should have spray under hot weather so that it will not turn color and appaer clear.
Evo Rocks !
Old 03-04-2006, 09:37 AM
Re: Mitsubishi GTO
I sprayed the subaru in normal living room temp, 22-25 celsius, in my basement.
Old 03-04-2006, 12:40 PM
NissanSkylineGTR98's Avatar
Re: Mitsubishi GTO
Nice work on the rear suspension, looking forward to seeing more of the car
Steve
Old 03-04-2006, 12:54 PM
zanthrax's Avatar
zanthrax zanthrax is offline
Re: Mitsubishi GTO
Try putting the can in warm water a few minutes before spraying.
Old 03-04-2006, 01:12 PM
Re: Mitsubishi GTO
Thanks, i will try to put it in water, but how hot should it be? 30 celsius or something like that?
Old 03-04-2006, 01:32 PM
toyota00 toyota00 is offline
Re: Mitsubishi GTO
I have read that you boil water, and then set the can in it for a few minutes? I am not totally sure though.
Old 03-04-2006, 02:42 PM
Re: Mitsubishi GTO
Allright, thanks for the tip =)
Old 03-04-2006, 04:44 PM
INsejn's Avatar
INsejn INsejn is offline
Re: Mitsubishi GTO
It should be so hot that you could put your hand in water without getting hurt. :P
Old 03-05-2006, 04:50 AM
Re: Mitsubishi GTO
Maybe i shouldnt boil it then
Old 03-05-2006, 05:25 AM
cfcrules's Avatar
cfcrules cfcrules is offline
Re: Mitsubishi GTO
I read about somebody who put it in boiling water and the can exploded so probably not.
Old 03-05-2006, 11:26 AM
drunken monkey's Avatar
Razor Sharp Twit
Re: Mitsubishi GTO
although if you do and it does explode, could you take a few photos so we could see the results?
Old 03-05-2006, 11:44 AM
Re: Mitsubishi GTO
haha , id like to try it, but i think i better dont..
Old 03-05-2006, 02:22 PM
Re: Mitsubishi GTO
The paint weant VERY wrong... al wrinkled and like spiderwebs, although the primer and paint is same manufacturer.. so im gonna get rid of all paint and redo the car =/
