Old 07-01-2002, 12:25 PM
skillz skillz is offline
engine swap for 2001 civic
I don't really know much about anything, except my car is slow as crap. I kinda want to get an engine swap or turbo. From what I have seen, there are no turbos out for 2k1 civics, and I don't really know what to look for in terms of an engine swap. What exactly would I need? Money is not an issue. Thanks in advance.
Old 07-01-2002, 01:25 PM
1995HondaCivic's Avatar
1995HondaCivic 1995HondaCivic is offline
Send a message via AIM to 1995HondaCivic
if money is not an issue get the rsx-r engine. i believe it's a k20 or something like that.
good luck, i saw one on JHP for $13,000
Old 07-01-2002, 01:28 PM
pardon my ignorance, they only want $12,000 obo for it
http://www.jdmhondaparts.com/4sale/rsx/pages/rsx_20.htm
Old 07-01-2002, 07:11 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
i wonder what happened to the original car...
anyways, i can custom turbocharge your car. i dunno how much boost your engine will hold though i say 6lbs if good enough.
Old 07-17-2002, 01:22 PM
Vizyun Vizyun is offline
Send a message via AIM to Vizyun
Lightbulb Well . . .
There is actually a k20a2 (RSX-S) engine swap being attempted at this very moment at IMPORT BUILDERS in california. A guy I know from www.7thgencivic.com (s/n htowncivicex) is putting it into his 7th gen coupe. He bought the engine off of e-bay for around $5500, and he's paying close to $3000 more in extra parts and labor to have it mounted. HAsport is SUPPOSED to be coming out with a set of motor mounts for the k20 engine to fit into an EM civic, but if they are, they're not out yet.
No one makes a turbo for the EM civic yet, so it'd have to be a custom job, which means warrenty may be negligible. If you wanted to turbo your D17, you'd only be able to run around 7 (if that) psi boost, unless you did MAJOR internal modification, and the gains STILL wouldn't match an RSX-S. Personally, I'd recommend the swap, if you have the money, then turbo the k20 (hell, it gets 200hp stock, with F/I it can EASILY blow the doors off of anything in your class). You're looking at a hefty price tag for all that (I believe Htowncivicex has bought RSX axles, front crossmember, and several other things, and they've had his car for over a MONTH). Go to www.7thgencivic.com and search the forums for "k20 swap" and you'll find it. Hope that helps!!!
"Vizyun is only limited to the distance between you and the horizon to which you aspire. . ."
--William D. Dingle
Old 06-25-2003, 07:56 PM
PWMAN's Avatar
PWMAN PWMAN is offline
I have found a kit for the D17 everyone!!!!!!! YEAH! No custom kit needed!
http://www.maxrev.com/index2.html
3000 dollars and then 329 extra for FMU. Thats not bad at all. I've heard MAXREV is the equivalent to FMAX turbo kits but without buying the name.
Old 06-26-2003, 02:31 AM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
some places are asking between 6 and 8 thou hasport has mounts and you can call hondata im sure the have something like jumper harness or wirining harnes. all you need to do is have the honda dealer ship unlock the ecu.
MODS: Motor :jdm b16 block, itr head, skunk 2 cam gears, msd ignition, intake, exhaust, straight pipe, skunk 2 ecu. act race clutch Suspension : grnd cntrl coilovers, 4 way adj shocks , spoon strut bar, skunk 2 sway bar, itr control arms, energy bushings misc. : super nice jdm seats, momo detachable steering wheel, Jdm clutster, Spoon Cf duckbill wing, vision smoked amber turn signals. COMING VERY SOON IN DAYS LS vtec ARP ROD BOLTS HEAD BOLTS AND 75 SHOT OF GIGLE JUICE look in my galler
Old 06-26-2003, 07:28 PM
nickzed20 nickzed20 is offline
http://www.hondatuningmagazine.com/f.../0301ht_heart/
if u didnt already go turbo, maybe u can get something outta that... would definately be worth it compared to turbocharging it
Old 07-13-2003, 03:50 PM
crociv crociv is offline
d17 tirbp kit
i have a 02 civic lx and i share the same problem as the person who asked what to do about his 01, it is slow as crap. i went to maxrev and the turbo they show is for the sohc vtech engine i have sohc and no vtech i wanted to know if that kit would work on my car too, and if not if anyone knew were to get kit from.
Old 07-13-2003, 10:28 PM
cabby_101 cabby_101 is offline
drop a cr-v engine b20b
160 hp@ 6000rpm
torque (lb.-ft)162 @ 3600rpm
2.4L
many people might think this is stupid but its something new and look at that torque if you want to do some drag racing or a quick start i think this is a great engine to drop in any honda
Old 07-19-2003, 04:53 PM
B20B is not 2.4L... its 2.0L B20(2.0)B
i think you are giving us the specs on the new crv engine... being the K24A. If this is what u ment, its a good idea if you want the extra torque. Alot of people are currently trying to make frankenstein engines with the 2.4L block. Be the first to put a k-series frankenstein in the 2001 civic
Old 07-19-2003, 06:46 PM
DIRTYDAWGS's Avatar
DIRTYDAWGS DIRTYDAWGS is offline
IF YOU NEED PARTS FOR THE K20A http://www.modacar.com/car/Acura/RSX/ HAS A LOT OF PARTS
ALSO http://www.todaracing.com/products/h...ngine_kit.html
http://www.raretrick.com/index1.asp?...10&Submit=View http://www.intensepower.com/rsx.html http://www.mvpmotorsports.com/merchant/rsx.shtml
DIRTY DAWG RACING !
I'VE BEEN
MY FUTURE CAR:95 240SX
CLICK HERE TO SEE FUTURE CAR
Old 07-19-2003, 06:49 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
what about the K24??? from the TSX?
200HP and probably lots of torque.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 07-19-2003, 08:01 PM
yea, thats pretty much what you would come up with if you take the 2.4L block (element, accord, new crv, etc.) and bolted on an acura rsx type S head. Except with these blocks, the rods and crankshaft, etc may not be as strong... also proper ECU tuning would be needed. If you have the money then the TSX engine is easier, but it will be alot harder to find and more expensive.
97 Jimmy engine swap gsnats Problem Diagnosis 5 03-06-2009 09:40 PM
engine swap for 98 civic coupe blingboy '96-'00 Civic 7 09-06-2005 07:53 PM
sup, engine swap for my civic 98 lx djmed '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 07-30-2003 10:15 AM
Engine Swap for '99 Civic Si BeEfCaKe '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 05-13-2002 08:35 PM
Engine swap for '87 Civic DX Getodd1 '71-'87 Civic | CRX 5 02-08-2002 11:29 PM
