Old 03-03-2006, 10:21 PM
tmoll5858 tmoll5858 is offline
electrical problem please help!!!
i keep blowing the fuse on my 92 blazer thats for the dash lights and my taillights. ive searched for wire problems and had a mechanic look at it too but nothing was found. does anyone have a clue or have had this problem?
Old 03-03-2006, 10:38 PM
old_master's Avatar
Advisor/Moderator
Re: electrical problem please help!!!
Are there any aftermarket accessories on the vehicle? Radio, CD player, trailer hitch wiring, etc etc. If so, start looking in those areas for shorted or corroded wires or connectors.
Old 03-04-2006, 12:24 AM
2kTrailBlazer's Avatar
2kTrailBlazer 2kTrailBlazer is offline
Send a message via AIM to 2kTrailBlazer
THIS IS NOT A PERMANENT FIX!
try putting a bigger (higher amp) fuse in for the time being...this does not FIX the problem but hides it until you figure it out. Lights that should be lit up that are not is a ticket...elctrical shit is a pain in the ass... can take you a while...just my thought
Old 03-04-2006, 12:41 AM
blazee's Avatar
blazee blazee is offline
Problem?
That's a good idea. When he figures out where the fire started, he'll know what the problem was....
Normally, the problem can be traced to the trailer wiring when the taillight fuse keeps blowing. I'd start there and then move to some of the other stuff that old master was talking about.
Old 03-04-2006, 01:10 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Check the trailer wiring harness and anything going back to the taillights.
Take the taillights out of the right rear tailight assembly and if the fuse does not blow, you have found where the problem is.
If it still blows it is the left assembly causing it.
If it is neither, then check your trailer wiring harness.
This will start the narrowing down process.
EDIT: Do NOT put a larger fuse in the place of the one blowing. That is just ridiculous even if it is a "temporary fix"
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-04-2006, 06:06 AM
Southern Comfort's Avatar
Southern Comfort Southern Comfort is offline
Like Old Master, Blazee,and Blazerlt said, Do not put a higher amperage fuse in your truck. The wires and connectors in your truck are rated for a specific amount of current( amperage), if you replace the fuse with a higher amperage fuse, the wires and connectore will get hot and the insulation will melt. That will just add more problems to your truck. If you have a multimeter and know how to use it, I suggest putting the black lead to ground and the red lead to both sides of the fuse and see if it reads a dead short, If you have a continuity check on your meter, it will beep, if not, your reading will read zero or close to that. If you don't know how t use a meter, then I suggest you find someone who knows how.
SC
Old 03-07-2006, 06:41 PM
sreve sreve is offline
you might want to pull the carpet back on the drivers side. wires for the rear lights ands the fuel pump run right under where the driver puts there feet.
Old 03-07-2006, 08:46 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
This is the most unheard of thing I've ever heard of. Don't kid your self, 12 volts DC CAN cause a fire.
I've seen burned out bulbs short out and blow fuses, not to mention frayed wires, or corroded terminals that got too hot and melted the insulation on the connectors.
If after you've traced all of the wires, harnesses, and checked all of the bulbs, looked and/or smelled for smoke or burning insulation to the best of your ability and can't find anything, take the truck in and get some professional help.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 03-07-2006, 09:12 PM
old_master's Avatar
Advisor/Moderator
Might as well wait til the fourth of July, get out the lawn chairs and a six pack, stick a 10ga jumper wire in there, sit back and enjoy the fireworks! After the fireworks, the kids can run around with sparklers and you can look for what the problem may have been.
Old 03-07-2006, 11:18 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
HAHA
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 03-07-2006, 11:29 PM
blazee's Avatar
Problem?
Alright guys, the point has been made. Let's ease up on him a little.
Old 03-09-2006, 05:22 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
THIS HAPPENED TO ME 2 . With that said , I put a bigger fuse in . JUST KIDDING . I GOT MY ELECTRONICS SCHOOLING THRU D MAIL .
The real stuff , My trailer had a short and after fixing it I still blew the fuse . Long story short , The contacts inside the older blazers light switch has a white dielectric grease in them . It was arcing thru carbon trails inside the switch popping the fuse . After taking the switch apart and cleaning the burned grease out and polishing the contact surfaces and reaplying grease ,mine works again . just my thoughts . Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 03-10-2006, 09:41 AM
alright guys i made an ignorant post...sorry tmoll... I must admit i probably shouldnt have posted considering i do not have much electrical expierence. At first thought it made some sense. Reading all the other posts i now know why someone would not want a bigger fuse.
