Old 03-03-2006, 09:12 PM
omaro86 omaro86 is offline
1st gear boost problems
Heres my problem, A few months ago I installed a profec-b EBC and have had the controller tuned for 13-14psi fine for all that time and never had one problem. Tonight I was driving and every time I tried to boost in first gear the car basically falls on it's face holds the boost at around 9 psi and it sounds crazy (starts popping out the exhaust) My first thought is that what I heard was the wastegates opening. I tried messing with every setting on the EBC and If i turned the boost down to 11 psi it stops doing it, but anything more no matter what the 3 settings are at it still does it. Whats going on here??
And something else I noticed driving around tonight was, I have my crap in the trunk (plastic trays, carpet, and spare tire out) ripping out dynamat from the prev. owner... with all that out I can hear my fuel pump in back running sitting at idle, during the time my boost prob was goin on I was sitting at a light and noticed it wasn't a consistant sound like "wwwweeeeeeeeeeeeee" but more like "wweeeeOOOwweeeOOOwweeeOOO" could there be something wrong with the fuel pump as well??
any advice appreactiated...
Old 03-07-2006, 12:36 AM
Igovert500's Avatar
blue + red light magnet
Re: 1st gear boost problems
Fuel pumps typically make a death whine when they go out. So that maybe your problem right there.
However, I'd still pressure test. How recently has any tuneup work been done?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-07-2006, 02:31 AM
Everything has been recently done, except fuel filter which I was planning on doing soon. Plugs and wires are also new.... About the fuel pump, I drove the car again yesterday, the fuel pump sounded normal and the car boosted fine... I drove it again tonight and it sounded different again, and the car also cut out again. I guess I'll try a new fuel pump, Thank you!!!
Old 03-07-2006, 02:40 AM
Igovert500's Avatar
Pressure test. Also does the weird sound possibly come from the engine bay, like an owl hooting under the hood?
What did you gap your plugs at?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-07-2006, 10:52 AM
Hotshot8792 Hotshot8792 is offline
? Thats turbos that whine when they're going bad. Fuel pumps whine when they are working. Haven't you ever heard the term whinebro? (the name given to walbro fuel pumps because they have the loudest whine of them all). The reason the whine isn't constant is because the voltage being provided to the fuel pump is low and isn't constant. This is why a lot of people hotwire their fuel pumps so that they can get the full 12+ constant volts to the fuel pump.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 03-07-2006, 01:15 PM
Well Thank you both now, I'm going to try and hotwire it first now, Ive alreay got the kit
Old 03-07-2006, 01:20 PM
Oops didn't see your reply.... Yep it's clear as day sitting in the car idiling that it's the fuel pump in the back. It's nothing under the hood, no owls like a leaking bov or turbo deathwhine Iv'e had them both. Oh and the plugs are at .32, that should be good for 13-15psi right??
Old 03-07-2006, 02:23 PM
Igovert500's Avatar
good call hotshot.
and yes .32 is fine for those levels.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
