Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-03-2006, 04:58 PM
MexRocket's Avatar
MexRocket MexRocket is offline
Any connection with anything?
I was just wondering if any of the problems I am having has anything to do with each other.
ON A FULL tank of gas, I just got 136 Miles... I know it is most likley the plugs and wires, which it has been 13k already for them.. so that is a given, but how much could that help the mileage? I will be looking at my fuel pump and hopefully rewiring it this weekend, will that affect anything? mileage wise?
The axel on the driver side has been completly opened, its the boot that is closest to the intermidiate shaft, What is the likley hood that it will just snap off? it's been like that for awhile, but hoping for warming weather before I buy another one. Would this also cause slower acceleration on that wheel? Is it also putting more pressure on my rusted suspension on that side?
2 studs to the manifold from the head have are gone, 1 was filled with a bolt screw dealy that is atleast 2-3 sizes bigger than the rest. The hole there is much larger and is stripped. 2nd one shot out or something when I was racing a camaro on the way home, It scard the living hell out of me when that happend because I just heard a metal ping and my car kinda shot back like it hit fuel cut. Not fun, There is a pretty bad exhause leak there, and the gasket that I put there is already kinda peeling away, ( I think it has a layer of something on top of the gasket) Is this damaging in any way my turbo? (which is on it's way out) I noticed that there is a loud screaming sound when I accelerate, so I am very VERY scared to push my car even past 3K rpms. Too many noises that make me think something is going to break. I know you use a heli-coil to re-thread or whatever to the head. But what about the one that is larger than the rest? Is it ok to have one bigger than all the rest?
Lastly, not to long ago I noticed that my BISS was filled in with I think rubber cement? Now, the cement or whatever has a hole in it and it is inflating when the car is on. My car now, or recently started reving at 500 rpms at a stop. Is there any connection? Thanks again for reading it.
STATUS: Near completion for the Engine
PROJECT BEST 1G IN IL:70% Done
MODS: C2 boost,mbc,B16GEGTurbo,12x28x3x3 FMIC,Ported2gmani,k&n.
Being bought in two weeks: Dsmlink,880's,3"exhaust,piping,suspension,axel,dri lled and slotted brakes.
Old 03-04-2006, 10:20 AM
MexRocket's Avatar
Re: Any connection with anything?
Bump?
Old 03-04-2006, 08:36 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
exhaust leak could cause it to run like ass, I could go into detail but I'm lazy(if you want me to explain it I can)
I wouldnt run on an axel like that, could be very dangerous
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 03-04-2006, 10:41 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
How about do a boost leak test? The other stud is a larger size, i think 10m x 1.25 but i'm not sure. I have a thread gauge so we can check it. The worst that will happen with the cv shaft is proabably already happening noise and vibration due to lack of lubrication. It could potentially completely break but not likely. As for acceleration on the you don't have a limited slip in the front so it would affect acceleration at all (except creating some drag on that wheel but it wouldn't be noticeable) I told you that whine is the turbo you can hear it cause the leaks in the exhaust manifold. You need a fpr first, you could also use a tune, i doubt bad plugs/wires would give you that horrible of gas mileage.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 03-05-2006, 01:20 AM
MexRocket's Avatar
The plugs and wires look fine, not a surprise on my car, I looked for shaft play on my turbo. Intrestingly the shaft play is still the same, no damage to the fins, no visiable signs of the blades hitting the wall, or anything, My air filter is ripped I just noticed, so that neesd to be upgraded, that is the stock orange one, so what is the part number for the K&N filter for 91 tsi's? The shaft as I said will be done during spring break or sometime warm, So hopefully it hold up. Rewiring the fuel pump is a must, and FPR i guess.
EDIT: Where is the best place do buy FPR?
Old 03-05-2006, 02:30 AM
ez1286's Avatar
kandn.com has the part number. I'd say buy a megan racing fpr http://meganracing.com/products/prod...asp?prodid=338 it's $90 on their site but you can probably get it for less on ebay.
Old 03-05-2006, 09:33 AM
blk_srt's Avatar
SBR sells 'em for $70
Mods:
