Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-03-2006, 03:53 PM
tsi95 tsi95 is offline
powerlock noise
I have a problem with the powerlocks. everytime i unlock my car it makes a wierd noise. i dont know if its the motor or if something electrical is contacting sometihng else. it only does it when i unlock my doors, and only the passenger side door does it. if i unlock it manually there is no noise. only when i unlock it from the unlock control on the door or from the door unlocking system that i had installed. please help because the noise is really getting to me
95 EAGLE TALON TSI
JDM swap
Turbo-XS HP Boost Controller
Old 03-03-2006, 04:21 PM
DragonofBC DragonofBC is offline
Send a message via AIM to DragonofBC
Re: powerlock noise
I think I had this problem before. Does it make a loud buzzing sound? If so, the gears have worn down in the door lock actuator and are grinding against each other. I bought an actuator off someone on DSMTrader and swapped the gears into mine. That part was simple. Getting the F&#@!*# thing disconnected, out of the door, and then back into the door is another story. I can give you a more detailed explanation if you need it.
2003 Mustang GT Convertible - 5sp. - K&N drop in, MAC catback, Eibach Pro Kit springs, Strange s/s, GMS UCAs/LCAs, MGW shifter, Nitto 275s out back. Does it ever end...
Old 03-09-2006, 10:38 AM
Re: powerlock noise
Yeah it is a buzzing noise. I got pissed off and disconnected it. your right it is a B%$#@ to unplug it, but yeah any info you can give me will be appreciated. thanks
95 EAGLE TALON TSI
JDM swap
