Go Back   Automotive Forums Car Chat > Ford > Falcon | Fairmont | FPV
Falcon | Fairmont | FPV Australian and American versions. Includes the XR6 and XR8 as well as FPV models like the Typhon.
Old 03-03-2006, 03:52 PM
evatip evatip is offline
Question Ford
Ford Fairlane 1977 petrol gauge wont read properly.sits on full and moves as I drive especialy when I go up hills. Or so if its low when I drive up hill the engine starts spluttering as if its starving for petrol but when Im on the straights it goes good again. When I say low its still about quarter of a tank in her.
Old 03-11-2006, 04:03 PM
Thunda Downunda Thunda Downunda is offline
Re: Ford
I'd get that fixed if I were you, it sounds like a real pain. Try taking it to a car repairer as these people are invaluable when it comes to getting your car repaired
Old 03-20-2006, 06:27 PM
C. Cleve C. Cleve is offline
Re: Ford
Hi, The sending unit in the tank is bad and or a bad connection at the tank wiring, giving you a false reading at the guage on the dash...Best answer I can give you for now....See Ya, Clay.......
Old 03-27-2006, 12:39 AM
tony36 tony36 is offline
Send a message via MSN to tony36
Re: Ford
The sending units are easy to replace. Does it ever go below full? If it stays on full, all the way to the top, you have a short, you are grounding out, if it moves down but not at the rate it is supposed to, like going from full to 1/4 instantly, then it's the sending unit. Those old ones are like a reostat switch and if there is a bad section it won't send at that level.
