Old 07-01-2002, 05:41 AM
rasher_b2 rasher_b2 is offline
Unhappy need help with spraypaiting
I was using a Tamiya spray can to paint the body of mt GTO but when it dried there were some "bubble" kinda things in 3 places I sanded them down and sprayed again but now the surface where i sanded them is all rough.how can i fix this and what caused those bubbles?
Old 07-01-2002, 05:55 AM
hrmodeler's Avatar
hrmodeler hrmodeler is offline
Send a message via ICQ to hrmodeler Send a message via MSN to hrmodeler
You can try to sand that parts where you have rough paint and than paint again. Or you must to remove whole paint from body.
Bubbles - maybe you didn't put primer or you put too much paint when you sprayed. Best way is too put primer, than few light coats and than few wet coats.
Zeljko Segin
http://www.hrmodeler.com - Fast wheels - my pages
My current project - .....
Old 07-01-2002, 07:23 AM
daggerlee's Avatar
I've gotten bubbles too using TS sprays. Seems like when shaking it up air bubbles in the spray can form and cause havoc on the model (it isn't a problem with enamels due to the slow drying nature of the solvent). Peter Johnson (I think that's his name) at tamiya.com recommends you shake the can by holding it at top and mixing the ball at the bottom of the can to remove this problem. I can't describe it very well, you should go check the article out, it's at the American portion of the page under Tips and Techniques.
Dan
Old 07-01-2002, 08:08 AM
Wishmaster's Avatar
Wishmaster Wishmaster is offline
***** Lurker
what daggerlee means, is you hold the cap of the spraycan, and make circles with the bottom, so the little ball in the can turns around and losens up the paint. Also puttingthe can in elbow warm water makes the paint smoother so it comes out more easy and bubbles shouldn't come.
Greetz
Stefan
Old 07-01-2002, 09:21 AM
daggerlee's Avatar
Yup, that's exactly what I mean! :flash:
Dan
Old 07-01-2002, 08:31 PM
primera man's Avatar
"P-Man"
Most bubbles will be from paint being to thick and traping air under the paint
View All My Models Here.
Old 07-01-2002, 11:02 PM
twoninety's Avatar
twoninety twoninety is offline
Send a message via AIM to twoninety Send a message via Yahoo to twoninety
I painted mmy Porsche Boxter uisng Tamiya spray paint. Somehow or other the paint "sputtered" and I ended up with a combination of small and large droplets on my model. Not very pleasant
Just gave it more coats and it worked out pretty ok
Old 07-01-2002, 11:07 PM
bri g bri g is offline
I've had that problem when I used spray cans before. It might be a problem with the spray can or in my case, it was the humidity. Did you paint outside on a cloudy day? the extra moisture in the air might have gotten in between coats.
