Old 03-03-2006, 08:49 AM
mehrshadvr4 mehrshadvr4 is offline
how do you count the knock on the engine?
i saw some people use race gas to have less knock.how do you read it? i have seen some people said 0 knock or 3 knocks.i need to know couse it will help me to boost safly on pump gas.
Old 03-03-2006, 09:35 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: how do you count the knock on the engine?
The knock sensor counts detonations inside the engine, and can be counted on a scan tool connected to the DLC. If your going to boost your engine, you need to use high test fuel. Higher combustion chamber pressures and temps normally require you to use it..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 03-03-2006, 12:46 PM
Igovert500's Avatar
blue + red light magnet
Race gas isn't necessary unless you are heavily modded. The stock turbos wont be able to flow enough air to need such high octane.
However, keeping an eye on knock is one of the best things you can possibly do when you start tuning. On obd1 cars (91-93) it is really easy. All you need is a datalogger and a palm pilot and you can monitor it while you drive, and turn up the boost accordingly. They are in teh process of doing making similiar software for the hybrids (94-94) and I think as of now, you can do it on them too. OBD2 cars (96-99) are the ones you can't. Which sucks. So for those, other tuning options become necessary. Such as a combination of monitoring wideband o2 readings and the ecu's timing control.
It is hard to explain all the options and factors for tuning, as there is so much. The best way is to really just read as much as you can, and ask when you don't understand, so that you can figure out which direction you want to take.
The bottom line though, if you have a 91-93, one of the first things you shoudl buy is a datalogger and palm pilot because it is an invaluable resource. Until you are monitoring knock, or learn to tune, you really shouldn't go above 14psi. Some say 14.5, or 15, but 14 about as much as I'd suggest pushing it. This works out well though, because the stock turbos (9bs) really can't do much better. Going beyond isn't really necessary until you make fuel/turbo upgrades.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-03-2006, 05:21 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Shiver has had his 94-96 loggers out for a while now. I want one.
And yes no need for race gas unless you are highly modded.
Old 03-04-2006, 12:08 PM
ok so what should i buy to count my knocks?i have 93 vr4.
Old 03-06-2006, 11:49 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
buy a cheap palm pilot off ebay. then get a datalogging program.
read through this thread and it should answer many of your questions: http://www.automotiveforums.com/vbul...ght=datalogger
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 03-06-2006, 11:58 PM
Igovert500's Avatar
http://automotive.miragecorp.com/
software and cables available here. Then all you need is a cheap palm off ebay like Linebckr mentioned.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 03-07-2006, 01:12 PM
Linebckr49's Avatar
oops. ya i forgot to mention the cable. you'll need one to connect the datalogger (palm pilot or laptop computer) to the in-car diagnostic port. i got my cable off ebay a few years ago for about 45 bucks. you might search around, i'm sure there are other options than the miragecorp $70 cable.
and as for datalogging software, the link i provided offers many differen't software options, and compares them. the open source one i use from MMCd is free and can log more parameters than the others. but you can read all about that.
93 3000GT base
Old 03-07-2006, 01:23 PM
Linebckr49's Avatar
the same guy i purchased my datalog cable from off ebay 3 years ago is still selling them on ebay! here's a link to some of his auctions: http://search.ebay.com/_W0QQfgtpZ1QQ...untdepolygonze. his cables only work with first gen 3S's (91-93), and since you have a 93 vr4, you're in luck. its 35 bucks, shipping included, so half the price of the miragecorp cable.
93 3000GT base
Old 03-08-2006, 08:52 AM
thank you guys
