Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-03-2006, 07:29 AM
Mirock Mirock is offline
dissapearing coolant. Help please
I'm an owner of 99 rodeo ls 4 wd 3.2 dohc almost 90k on it ,here is a problem.About 4 months ago chenge a timing belt and water pump and since then i'm notticing a lose of coolant ( went low twice already luckilly didn't overheat) .I did crawl under the truck numerous times and check top af the motor ,i can't find anything leaking or smell an antifreeze ,it is a mystery to me where the coolant goes ? Could it be a head gasket leaking? but on the other hand there is no coolant in oil or vice -versa ,cooling system is not getting pressurized like it usually happening with bad head gasket .Did anyone here experienced the same problem? .Can you help me guys.
99' rodeo 4X4 LS
99' mazda 626 wife's toy
Old 03-03-2006, 10:49 AM
rodeo02 rodeo02 is offline
Re: dissapearing coolant. Help please
Pull the spark plugs to check for coolant in the plug wells. That's a sure way to check for a head/gasket leak on the 3.2/3.5's. Unfortunately 1998/1999's were prone to head cracks & coolant leakage into the combustion chamber.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-03-2006, 03:40 PM
directory's Avatar
directory directory is offline
i hate when you bring that up
i'm sure glad i have a 99 honda passport...
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 03-06-2006, 03:29 PM
99zhfkaf 99zhfkaf is offline
i am having the same issue w/my 99 passport. i thought it was a radiator, had it replaced and a month later i was low again. no idea where the coolant goes, no drips or smells. my mechanic claims all tests say head and block are fine. no white smoke out of the tailpipe either. he thinks it's a small leak near the thermostat, in an area covered by the intake plenum(sp?), engine cover and pretty much everything on the top of the motor. let me know if you find anything out. right now i am just checking my coolant level every 2-3 weeks and topping off as necessary.
Old 03-06-2006, 06:09 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
An easy way to tell if coolant is getting into the oil is to pull the dip stick out and taste the oil (just taste a drop, dont drink it).
Even a little bit of coolant in the oil will make it taste sweet. It wont hurt you, I have been doing it for years. It also gives you a reason to have an adult beverage afterwards to get rid of the oil taste.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 03-06-2006, 06:24 PM
sandyf43935 sandyf43935 is offline
Ewwww.
That's all. Ewwww.
Old 03-06-2006, 07:49 PM
Originally Posted by Gizmo42
..pull the dip stick out and taste the oil (just taste a drop, dont drink it)..
Gizmo, yer killin' me !
Joel
Old 03-07-2006, 05:06 PM
surferfletch surferfletch is offline
Did they pressure test it?
