Old 03-03-2006, 01:46 AM
86 CHEVY 86 CHEVY is offline
Durmax Diesel
Does anyone have a Duramax Diesel with Dual Exhaust? Im interested in knowing what the price range was on the whole kit.
We Ride together, We Die together, GM for Life.
Old 03-03-2006, 11:43 PM
01silverado03z400's Avatar
01silverado03z400 01silverado03z400 is offline
Send a message via MSN to 01silverado03z400
Re: Durmax Diesel
I've never seen dual exhaust for a duramax but im sure that if you go to a muffler shop they can make it for you and it would be a whole lot cheaper than buying a kit(which might not exist). Probably under $300.
NEW - 2004 Chevrolet Silverado 5.3L RCSB Z71 Hooker AeroChamber - Black Bear Tune - Welds - 33" Mickey Thompsons
01 Silverado 4.8L ECSB 4x4 True Flow - Magnaflow - Black Bear Tune - 35" BFG A/T - 4.56 Auburn SOLD
83 Sierra RCSB 2wd 350 Under construction
Old 03-04-2006, 08:54 PM
Re: Durmax Diesel
O thanks, in that case if its a do it yourself thing, then ill just fabricate it myself at my welding shop. You have never seen dual exhaust on a Duramax?
It sounds so good man. I think I can just chop it and do it up myself.. thanks again.
Old 03-04-2006, 09:14 PM
Re: Durmax Diesel
I've never seen a Duramax with dual exhaust but my neighbor did hav one with like a 6" tip. IT WAS HUGE haha! I've seen Ford Powerstrokes with duals and i just looked it up on google so im pretty sure that duals for duramax exist. On google all i could find was single in / single out with a forky looking thing that welds onto the single out. But if you just want a nice sound with a slight hp increase without paying a lot then fabricating it is the way to go. If you have your own shop then itll be even cheaper for you .
Old 03-04-2006, 09:25 PM
06Z71 06Z71 is offline
Re: Durmax Diesel
Just cut it all off !!!!!!!!!!!!
Cranked Bars
Silverstar headlight + 8 Light Mod
TrueFlow Intake + Airaid TBS
5% Window Tint + 30% On Front Windshield
Billet Grill + Bugshield + Ventvisors
And Still Spending
Old 03-05-2006, 01:47 PM
Re: Durmax Diesel
Yea im gonna chop it all off and just order tubing and such, then fabricate it myself. If you wanna see the kit for a Duramax Diesel Dual Exhaust, check this out: http://www.dieselmanor.com/exhaust/gm-ss-dual.asp . Im not gonna buy the kit I dont think, I was just looking at it and still debating it. But thanks man. Check out the video on that site to, sounds pretty good there.
Old 03-05-2006, 02:19 PM
Re: Durmax Diesel
I think thats the one that I saw on google. Like I said its not true dual exhaust it just has the fork. 06Z71 said to chop it all off and i think he meant to cut everything off and leave it off so that it looks smooth and sounds loud. When fabricating it try not to use really wide tubing or else you will lose some low end power because there wont be any backpressure. Since your going to make duals i would use the same width off tubing as stock or smaller and just go with really wide tips if thats the look you want. Even if you lose some in the low end you will gain a real kick in the pants in the higher rpms.
Old 03-05-2006, 05:12 PM
Re: Durmax Diesel
Ok 06Z71, what do you suggest.. I want to know what you would do personally. Thanks to 01silverado03z400 for his information, he pretty much appointed me in your direction about this topic. So tell me, would you chop it all off and leave it or, chop it all off and then fabricate it yourself with 4" tubing with like 6" tips? Just wanna know your personal opinion, then ill decide what im gonna do.
Old 03-06-2006, 08:35 AM
Re: Durmax Diesel
Chop it all off and leave it off, very clean look, But I would install a turndown on it to get the exhaust out from under your truck (WARNING!!!!! this way may have a lot of cab noise)
Cranked Bars
And Still Spending
Old 03-06-2006, 01:15 PM
Re: Durmax Diesel
What if I chopped it all off and brought it out the side on a 45 degree or so?
Old 03-06-2006, 03:24 PM
Re: Durmax Diesel
I saw a truck that had that today it look good but it look like he had a 6" tip going in to a 4" pipe that was a little much. My
Cranked Bars
And Still Spending
Old 03-06-2006, 08:04 PM
Re: Durmax Diesel
What was so much about it? Was it to loud or.. what?
Old 03-07-2006, 08:23 AM
Re: Durmax Diesel
The look of going from a 4" pipe to a 6" tip. It just didn't look right
Cranked Bars
And Still Spending
Old 03-07-2006, 05:35 PM
Re: Durmax Diesel
if your going with a 6" tip from a 4" pipe make sure that ur tip is at least a foot or longer then it doesnt look so bad.
Old 03-07-2006, 06:21 PM
Re: Durmax Diesel
Yes!! Then its decided, ill bring it out on the side on less then a 45 degree, with a 6" tip on it that looks like its a part of the pipe, so basically looks like I have a 6" exhasut pipe. Great, thanks boys!!
