Old 03-02-2006, 09:35 PM
justinsz8's Avatar
justinsz8 justinsz8 is offline
Question weird stuff going on
The dome light in my '98 Z28 keeps coming on when driving down the road, but when I put the window up it goes off. so I am assuming that the door switch is going bad. but I can't find it in the door jam anywhere? Am I blind or is it in the door latch itself on the '98 models? This is very annoying, I had to pull the fuse for now to keep the dome lights from coming on at night when I am driving and to keep the dome light from coming on in the middle of the night and setting off the alarm. With that fuse pulled, I can't use keyless entry which is really annoying for a lazy person such as myself!
Another problem. Whenever it is really cold outside, and I go to start my car in the morning it runs like ass. Like a carburated motor with no choke. I have to sit out there and babysit it keeping it running till the motor gets warm. I assumed that since it was air temperature that was messing with it, that it would of been the Air Temperature Sensor. Replaced that, and it didn't make any difference what so ever. Also, it never kicks on the Check Engine light even though it is running like crap.
Old 03-02-2006, 09:40 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: weird stuff going on
ok for the dome light make shure that, that little spindel thing by where you turn off the lights is not pushed up all the way. And the door things are under little black rubber boot things so it just looks like a little black nob thing. and i think it is located right by the door pin area. as for the cold start thing, it kinda sounds like a bad o2 sencer, but there is no check engine light, so i don't know.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 03-02-2006, 09:42 PM
97cavalier's Avatar
have you done any mods lately? that might make it run like crap for a little bit till the computer relearnes every thing again. try to pull the batter cables off over night and hook it back up and see if that helps any.
Old 03-02-2006, 09:55 PM
justinsz8's Avatar
alright, I know which little black knob thing you are talking about and will check that out. I haven't done any mods to it, although someone had put a K&N filter on it before I bought it. I have tried disconnecting the battery cables already. the O2 sensor makes sense, it doesn't idle totally smooth when it is warm out either, but it is so minimal you can't notice it unless you really pay attention. The no check engine light, doesn't make any sense though?
Old 03-02-2006, 09:57 PM
97cavalier's Avatar
how manny miles are on it? you might want to try to clean the throttle body out, i know they can get gumed up badly.
Old 03-02-2006, 09:58 PM
justinsz8's Avatar
149,000
Old 03-02-2006, 09:59 PM
97cavalier's Avatar
oh ya, clean that throttle body out, i bet that thing is nasty!!
Old 03-02-2006, 10:00 PM
justinsz8's Avatar
I'll give that a try this weekend. it probably needs it regardless. can you use regular old carb cleaner on it?
Old 03-02-2006, 10:02 PM
97cavalier's Avatar
ya, but i don't think you can on tha little sencer on the throttle body, i think it is plastic and it will eat away at it, so just wip that sencer clean with a towl, and use carb and choke cleaner on the throttle body.
Old 03-02-2006, 10:15 PM
justinsz8's Avatar
just went and looked at the door and door jam, there's no switch or anything on there anywhere. I even searched the bottom of the door. That switch has got to be integrated into the latch assembly. I will call the GM dealership in the morning and see if they can look it up for me. thanks for you help.
Old 03-02-2006, 10:16 PM
97cavalier's Avatar
ya, i have seen the little black rubber thing on 95's so i thought it might be the same on this.
Old 03-02-2006, 10:20 PM
justinsz8's Avatar
knowing my luck I will have to replace the whole latch!
Old 03-07-2006, 09:46 AM
justinsz8's Avatar
The GM dealership doesn't even know where it is located at! It has to be in the latch assembly.
Old 03-07-2006, 10:56 AM
FireFox05's Avatar
FireFox05 FireFox05 is offline
Send a message via MSN to FireFox05
That's a good bet, or look for some sort of magnetic contact point or a place for current to run through. I'm not sure.
1998 GTP sedan
Mods:MPS 3.4|180Tstat|PowrTuned|AL104's|SSAC's|DIY HAI|F-body's|GMPP H.K.|Gen2 SSC|KYB GR-2|Hand e-brake|Bucket Rear Seats
Soon:Appearance mods|some secret stuff|Audio stuff
Future: 12 second DD
Old 03-07-2006, 11:01 AM
justinsz8's Avatar
I found it, it is part of the latch assembly.
