Old 03-02-2006, 10:18 PM
nrlemons's Avatar
nrlemons nrlemons is offline
backfire sound
What is causing this i guess you would call it backfire? I dont really know how to describe it so i'm just gonna post this video.
the tailpipe is just off the top of the screen, somehow the sound got behind the video and that little puff of stuff that comes out is right when it makes that backfire sound not when its revving up like in the video. Its a 98 blazer LT with 83,000 miles. I just changed out the fuel filter and pvc, if that would make any difference. I never remembered it making this sound before.
Much Thanks,
Josh
Old 03-03-2006, 04:27 AM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
Re: backfire sound
It sounds like a aftermarket exhaust with little baffling to me! anyone else?
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 03-03-2006, 06:10 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
Re: backfire sound
It looks like you have fuel still burning in the exhaust . Maybe a plug not firing every cycle or a litte rich . Is that cold condensation on the ground or was the engine completely warmed up ? At night , can you see flame ? cool if so . Exhaust valve openning too early ? rocker arm too tight ? Good luck , Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 03-03-2006, 10:36 AM
Eslhockey92g's Avatar
Eslhockey92g Eslhockey92g is offline
Re: backfire sound
I agree. I deff has a deeper idle than stock, just the way mine 97 w/ a flowmaster sounds. It to gurggles like that when the rpms fall from me reving it a lil.
Old 03-03-2006, 11:58 PM
nrlemons's Avatar
Re: backfire sound
i'm due for new plugs, thats probably what i'll try next. but yeah thats the stock exhaust. Although i'm not sure how good of a condition its in, it seemed louder after driving through some water one day and has a few dents in the muffler but i cant find any cracks so who knows? I'll hopefully be getting a Flo-pro exhaust here in a few weeks, i'll post another vid if I do.
Old 03-04-2006, 02:14 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: backfire sound
I don't deem that backfire. I have heard perfectly tuned engines pop like that when the rpms are falling.
It could be anything really including a little water in the muffler.
Try drilling a tiny hole in the bottom rear of your muffler at the lowest point below where the tailpipe attaches to the muffler.
This will remove any water in the muffler and also extend the life of it as well.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-04-2006, 09:55 PM
old_master's Avatar
Advisor/Moderator
Re: backfire sound
Typically a backfire on deceleration is associated with a system that incorporates an air pump, (A.I.R. or air injection reactor). However, 1998 Blazer is not equipped with that system. The AIR system is designed to pump fresh air in to the exhaust manifold on acceleration and cruise only. If the diverter valve fails, it will allow fresh air into the exhaust on deceleration also, causing a series of small backfires. When the relatively cool fresh air is introduced to the hot, fuel-enriched exhaust, a “thunder storm” of sorts happens. If you have been around a vehicle with open headers, they backfire on deceleration also. Same principal, very short exhaust pipes and the exhaust does not cool down gradually, as it does in a full exhaust system. Point being, I would look for an exhaust leak, possibly a cracked manifold, or a leaky gasket; it doesn't need to be large to cause backfiring.
Old 03-05-2006, 08:09 PM
Teal95Jimmy's Avatar
Teal95Jimmy Teal95Jimmy is offline
Send a message via AIM to Teal95Jimmy
Re: backfire sound
Kind of sounds like the baffling in the muffler has rotted out. That's what mine sounds like right now, time for a new one at least for me
