Old 06-30-2002, 07:03 PM
AznRide's Avatar
AznRide AznRide is offline
Send a message via AIM to AznRide
Si Ecu Help!!!!
I bought a 99 civic SI ecu (P2T) and I assumed that it would fit my brother's 96 civic ex. It didn't. Why? Cause I heard that people switching ecu and stuff but I didn't look close into it. Can someone help me out. What should I do with the ecu? It's available for sale if I dont make it fit. Let me know. thanks
"I never had a dream come true, 'til the day that I found you, even though, I pretend that I've moved on, you'll always be, my baby..."
- S Club 7
Old 06-30-2002, 07:36 PM
luti luti is offline
Send a message via AIM to luti
I don't think the Si is swappable with the EX because of the DOHC and SOHC differences. Correct me if I'm wrong but that's just what I've read.
T3/T04E turbocharged ricer.
Old 07-01-2002, 05:00 PM
AznRide's Avatar
cause i had a obd2-obd1 conversion harness with my obd1 gsr ecu and i plugged it in my bro.'s car and worked fine...so I thought obd2 si would be find but one of the plug in couldn't plugged in (the smallest plug) Weird.
- S Club 7
Old 04-28-2004, 09:51 AM
Soupee9 Soupee9 is offline
Si Ecu
the ecu for the si(P2T) is OBD IIb whereas any civic 96-2000 other than the si uses ODB IIa. check www.hondata.com, they have pictures regarding the differences.
Old 04-29-2004, 03:28 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Si Ecu
BINGO! That's the answer.
Also it sounded like you were trying to plug the OBD1 adapter into the Si ECU? If so, you can't plug OBDI plug into OBDII ECU.
Also of note, an Si DOHC B16 ECU most likely WON'T work on a SOHC motor, as there is different control due to the 2nd cam of the B16, which your D16Y8 motor lacks, even though it still has VTEC.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
